LVGL tft and SD on same SPI
I would like to read from my SD card while LVGL is running
tried using #include <esp_littlefs.h> #include <littlefs.h> #include
lv_conf.h >>
/** API for Arduino LittleFs. */
#define LV_USE_FS_ARDUINO_ESP_LITTLEFS 1
#if LV_USE_FS_ARDUINO_ESP_LITTLEFS
#define LV_FS_ARDUINO_ESP_LITTLEFS_LETTER ‘S’ /< Set an upper-case driver-identifier letter for this driver (e.g. ‘A’). */
#define LV_FS_ARDUINO_ESP_LITTLEFS_PATH “/” /
< Set the working directory. File/directory paths will be appended to it. */
ESP32 dev / 8MB
  • LVGL version:
  • 9.4
when compiling, I get the error lib/lvgl/src/libs/fsdrv/lv_fs_arduino_esp_littlefs.cpp:58:5: error: ‘LittleFS’ was not declared in this scope.
I tried using just SD as a stand alone. (my own library) however there was not a good method found to set CS high on tft display while SD was reading / writing. Help would be greatly appreciated.
If you’re using Arduino Core, check out LovyanGFX library
LovyanGFX is also integrated in LVGL, you can find the FS example here
