What are compatible LVGL Test Automation framework?.
I have LVGL application. I don’t want to check each feature manually, are there any python library or anything to fully test LVGL Application?
Note: I want test automation to be separate executable. Test Automation much use application .exe file and perform test case execution.
Is there any way to do it?
Monkey — LVGL documentation
maybe you can use this function.
I assume Monkey testing technique is used for Stress testing. my expectation is to automate steps in LVGL
On the LVGL email Newsletter from March 7 they announced UI Testing Tools. Here’s the link for documentation:
https://docs.lvgl.io/master/details/auxiliary-modules/test.html
From the Newletter:
“Testing user interfaces just got easier! LVGL now includes built-in tools for display emulation, input simulation, screenshot comparison, and more—no need for an external setup.
You can now:
Create a virtual display for testing
Simulate clicks, button presses, and other interactions
Compare screenshots to detect UI changes
Measure memory usage and retrieve widget properties
These tools are completely flexible and work with any testing framework—you decide how to integrate them into your workflow!
Best of all, they’re open-source, MIT-licensed, and built directly into LVGL.”
great work ! are there any plans on also adding some sort of id’s to the widgets, so that you can target them via those ( along with different selectors , byWidgetType, byClass, … ) because coordinate testing can become quite annoying because you have to rewrite all the coordinates when your layout changes.
See https://github.com/barkleyli/LVGL-UI-Automation-Framework. You can use Python to create automation tests.
What is LVGL-UI-Automation-Framework? A comprehensive testing and automation framework for LVGL-based user interfaces. Enables automated UI testing, screenshot capture, and interaction simulation for embedded and desktop applications. Includes a fully testable smartwatch demo application that demonstrates best practices for building LVGL UIs with testability from day one.
You may find this post useful:
LVV - LVGL Test Automation Tool
