I Have an LCD RGB666 format, I see in lv_conf.h, the LVGL support 8 (RGB332), 16 (RGB565) and 32 (ARGB8888).
What can I do to adapt the library to the screen?
The LCD is COM37H3N83ULC.
Best Regards,
I would suggest using RGB565 and converting the colors to the right format in your display driver’s flush_cb function. You probably won’t see much benefit from going with ARGB8888.
Other question
Can I do this?: Configure the LVGL to RGB565 and set the LCD LSB R[0] and B[0] to GND.
Do you see this as a solution?
Best Regards.
Hi All,
We are also using LCD with RGB666 format. But in LVGL side (lv_conf.h) its mentioned as below,
/* Color depth:
Will LVGL support RGB666 Pixel format?
