the following is my description of the problem, I hope everyone can help to solve this problem, thank you very much.
My project is about streaming media, one of the features is to view the file list.But I meet a problem when I operate list A to list B:
I‘m repeatedly deleting and creating a list, and repeatedly changing the text content of the buttons in the list.
When I repeat this operation to the 91st time.lv_task_handler stopped working because there is no more print information.But the system is running normally.
Arm+Linux LVGL:7.0.5
What do you experience?
I tested it about 8 times, and there was no response at the 91st time.At the same time, the CPU usage has become 100%(Usually takes up 4%). But what I am doing is repetitive.
What do you expect?
I hope to solve or avoid this problem
I made a simplified version of the demo.During the board test, the mode is switched once about 5s
int file_totalnum = 0;
int file_current_page = 1;
int file_total_page = 1;
int mode = 1, file_foucus_pos = 0;
lv_obj_t * label_mode;
lv_obj_t * pblist_cont;
lv_obj_t * pblist_list;
lv_obj_t * pblist_btn[10];
static lv_style_t style_cont2;
static int gui_obj_enable(lv_obj_t * obj, bool en)
//if (obj == NULL)return -1;
if (en == 1)lv_obj_set_hidden(obj, 0);
else if (en == 0)lv_obj_set_hidden(obj, 1);
else lv_obj_set_hidden(obj, 1);
return 0;
static void test(void)
lv_obj_t * title_cont = lv_cont_create(lv_scr_act(), NULL);
lv_obj_set_size(title_cont, 320, 30);
lv_obj_set_pos(title_cont, 0, 0);
lv_style_init(&style_cont2);
lv_style_set_bg_opa(&style_cont2, LV_STATE_DEFAULT, LV_OPA_0);//LV_OPA_0
lv_style_set_bg_color(&style_cont2, LV_STATE_DEFAULT, LV_COLOR_RED);
lv_obj_add_style(lv_scr_act(), LV_BTN_PART_MAIN, &style_cont2);//
/*Mix text and symbols*/
label_mode = lv_img_create(title_cont, NULL);
lv_obj_set_pos(label_mode, 5, 5);
lv_img_set_src(label_mode, LV_SYMBOL_VIDEO);
//lv_label_set_text(g_GUI.title.obj.label_mode, LV_SYMBOL_VIDEO);
lv_obj_t * label_time = lv_label_create(title_cont, NULL);
lv_obj_set_pos(label_time, 94, 8);
lv_label_set_text_fmt(label_time, "%s", "07/23 15:33:30");
gui_obj_enable(label_time, 1);
pblist_cont = lv_cont_create(lv_scr_act(), NULL);
lv_obj_set_size(pblist_cont, 320, 210);
lv_obj_set_pos(pblist_cont, 0, 30);
lv_obj_t * pblist_title = lv_label_create(pblist_cont, NULL);
lv_obj_set_pos(pblist_title, 10, 2);
lv_label_set_text_fmt(pblist_title, "%s", "Files:");
lv_obj_t * pblist_filepage = lv_label_create(pblist_cont, NULL);
lv_obj_set_pos(pblist_filepage, 10, 190);
lv_label_set_text_fmt(pblist_filepage, "%s%d/%d", "Page:", file_current_page, file_total_page);
lv_obj_t * pblist_filenum = lv_label_create(pblist_cont, NULL);
lv_obj_set_pos(pblist_filenum, 230, 190);
lv_label_set_text_fmt(pblist_filenum, "%s%d", "Total:", file_totalnum);
gui_obj_enable(pblist_cont, 0);
static void change_mode(int mode)
int i;
if (mode == 2)//mode A
file_totalnum = 6;//for test
pblist_list = lv_list_create(pblist_cont, NULL);
lv_list_set_scroll_propagation(pblist_list, 1);
lv_list_set_scrollbar_mode(pblist_list, LV_SCROLLBAR_MODE_DRAG);
lv_list_set_anim_time(pblist_list, 0);
lv_obj_set_size(pblist_list, 320, 170);
lv_obj_set_pos(pblist_list, 0, 20);
for (i = 0; i < 10; i++)
pblist_btn[i] = lv_list_add_btn(pblist_list, NULL, " ");//10 files per page
//gui_update_playback_listbtn(RECORD_FILE_TYPE_VIDEO);//update playback list
gui_obj_enable(pblist_cont, 1);
else if (mode == 3)//mode B
//This mode will change the text content of each button in the list, and do get and set operations
file_totalnum = 5;//5 for test
//gui_update_playback_listbtn(RECORD_FILE_TYPE_PHOTO);//update playback list
else if (mode == 1)//mode C
if (file_totalnum != 0)
lv_obj_clean(pblist_list);
int mode_test=0;
int main(int argc, char** argv)
hal_init();
test();
while (1) {
mode_test++;
if (mode_test > 3)mode_test = 1;
change_mode(mode_test);
lv_task_handler();
Sleep(5);
Usually stopped on this interface, This interface would have refreshed the content in the list.
