LVGL simulator with v9.x
In v8 the simulator had lv_win32_quit_signal, in v9 how is this achieved?
PC Simulator Visual Studio Windows
I have timers running on my screens and when I close the app, it ends up with an exception, if I do not start the timer, it closes nicely.
Disable the timer when compiling.
void init_screen(void)
static lv_style_t style_bg;
static lv_obj_t * bg_box;
static lv_obj_t* tbl_box;
lv_timer_create(update_cb, 33,  NULL);
I suspect you need to delete the timer upon closing the app?
lv_timer_create() returns an lv_timer* . I do not know how the simulator works but is there something that is called when the application closes? You should delete the timer there I guess.
I always create a delete event for when a screen gets deleted in which I delete the timer, perhaps this is an option for you? If you do not delete the timer manually it will stay alive. Here’s how I do it:
static void ev_Delete_cb(lv_event_t* event)
    lv_timer_t* timer = lv_event_get_user_data(event);
    if (timer != NULL)
        lv_timer_delete(timer);
void initScreen(lv_obj_t* screen)
    lv_timer_t* timer = lv_timer_create(tim_Update_cb, 100, labStatus);
    lv_obj_add_event_cb(screen, ev_Delete_cb, LV_EVENT_DELETE, timer);
Thank you, it works!
