LVGL setup for Makerfab Matouch 7inc display - HELP
Hi, I’m struggling to make work my Makerfabs Matouch 7 inc display with LVGL with Arduino IDE on Windows 10.
Is there someone that was able to make it work?
I use LVGL on other display such as CYD always based on ESP32 even if with some differences.
I’m searaching for a clear guide to setup the enviroment, and how to setup the TFT_eSPI User_setup file and lvgl_conf.h file for this board.
Board Specs:
  • Controller: ESP32-S3-WROOM-1, PCB Antenna, 16MB Flash, 8MB PSRAM, ESP32-S3-WROOM-1-N16R8
  • Wireless: Wifi& Bluetooth 5.0
  • LCD: 7 inch High Lightness IPS
  • FPS: >30
  • Resolution: 800480/1024600
  • LCD interface: RGB 565
  • Touch Panel: 5 Points Touch, Capacitive
  • Touch Panel Driver: GT911
  • USB: Dual USB Type-C(one for USB-to-UART and one for native USB)
  • UART to UART Chip: CP2104
  • Power Supply: USB Type-C 5.0V(4.0V~5.25V)
  • Button: Flash button and reset button
  • Mabee interface: 1I2C;1GPIO
  • MicroSD: Yes
  • Arduino support: Yes
  • Type-C Power Delivery: Not Supported
  • Operation temperature: -40℃ to +85℃
Thanks
Unfortunately TFT_eSPI doesnt support this display type.
Did you try following the tutorial here?
Regards
Yes I did, but I can’t compile the code. I received a lot of compilation error like this:
E:\Documenti\Arduino\clock\clock.ino:23:8: error: 'lv_disp_draw_buf_t' does not name a type; did you mean 'lv_draw_buf_t'?
        lv_draw_buf_t
In this case I was using the AdafruitGFX library.
thanks for your time.
What version of lvgl did you install?
I installed lvl v9.1.0
Ah.
Try 8x or follow the upgrade documentation:
The link I did supply had it’s own version of LVGL, Did you miss that?
So you suggest to try an older version i guess. I can try but I’m working with other other boards that are using 9.1.0.
But how can i make the board work also with the latest release? I would like to be able to configure the environment to make the device work, without remain stuck to the Makerfab old code.
I already posted the upgrade notes:
I solved this problem using lovyanGFX and lvgl9
