LVGL 9.3 on STM32H750 with LTDC Full Render Mode
STM32H750XBHX - CubeMx 1.16.0
I’m using 2.1" 480x480 Round LCD to make Custom Gauges to my Car.
My project was working fine. I have QSPI flash, SDMMC working, LCD shows and SDRAM works without any problem. I can open files from SDCard with FatFS and show images on my LCD. All works without problem. Now I need to start making the GUI
I’ve downloaded lvgl-master (v9.3) from GITHUB
I’ve move the files to my project root directory.
renamed it only “lvgl”
renamed the file “lv_conf_template.h” to “lv_conf.h” and set “#if 1”
I’ve made a file “lvgl_port_display.c” in my Core/Src directory and necessary header file.
I’ve made the “lvgl” directory into PATH with Properties> C/C++ Build> Settings> MCU/MPU GCC Compiler> Include paths> Add Path “…/lvgl”
#ifndef __LVGL_PORT_DISPLAY_H
#define __LVGL_PORT_DISPLAY_H
#ifdef __cplusplus
extern "C" {
* INCLUDES
#include "../lvgl/lvgl.h"
* DEFINES
#define MY_DISP_HOR_RES 480
#define MY_DISP_VER_RES 480
#define MY_DISP_BUF_SIZE MY_DISP_HOR_RES * MY_DISP_VER_RES * 2
* GLOBAL PROTOTYPES
void lvgl_display_init (void);
#ifdef __cplusplus
} /*extern "C"*/
#endif /* __LVGL_PORT_DISPLAY_H */
* INCLUDES
#include "lvgl_port_display.h"
#include "main.h"
#include "ltdc.h"
#include "dma2d.h"
#include "sdram.h"
* STATIC PROTOTYPES
static void disp_flush (lv_display_t *, const lv_area_t *, uint8_t *);
* STATIC VARIABLES
static lv_display_t * disp;
//static lv_thread_sync_t sync;
#define LVGL_BUFFER_1_ADDR_AT_SDRAM (SDRAM_BANK_ADDR)
#define LVGL_BUFFER_2_ADDR_AT_SDRAM (SDRAM_BANK_ADDR + MY_DISP_BUF_SIZE)
* GLOBAL FUNCTIONS
/* display initialization */
disp = lv_display_create(MY_DISP_HOR_RES, MY_DISP_VER_RES);
lv_display_set_buffers(disp, (void*) LVGL_BUFFER_1_ADDR_AT_SDRAM, (void*) LVGL_BUFFER_2_ADDR_AT_SDRAM, MY_DISP_BUF_SIZE, LV_DISPLAY_RENDER_MODE_DIRECT);
HAL_LTDC_SetAddress(&hltdc, (uint32_t)LVGL_BUFFER_2_ADDR_AT_SDRAM, 0); // start with the second buffer: LVGL will render into the first buffer
lv_display_set_flush_cb(disp, disp_flush);
* STATIC FUNCTIONS
static void disp_flush (lv_display_t * display,
const lv_area_t * area,
uint8_t * px_map)
if (lv_display_flush_is_last(disp))
SCB_CleanInvalidateDCache();
// wait for VSYNC to avoid tearing
while (!(LTDC->CDSR & LTDC_CDSR_VSYNCS));
// swap framebuffers (NOTE: LVGL will swap the buffers in the background, so here we can set the LCD framebuffer to the current LVGL buffer, which has been just completed)
HAL_LTDC_SetAddress(&hltdc, (uint32_t)(lv_display_get_buf_active(disp)->data), 0);
lv_display_flush_ready(disp);
But When I Rebuild the code, I get those errors.
C:/ST/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/…/lib/gcc/arm-none-eabi/12.3.1/…/…/…/…/arm-none-eabi/bin/ld.exe: ./Core/Src/lvgl_port_display.o: in function `disp_flush’:
C:/Users/emre2/STM32CubeIDE/workspace_1.16.0/RoundLCD-SDRAM/Debug/…/Core/Src/lvgl_port_display.c:51: undefined reference to `lv_display_flush_is_last’
C:/ST/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/…/lib/gcc/arm-none-eabi/12.3.1/…/…/…/…/arm-none-eabi/bin/ld.exe: C:/Users/emre2/STM32CubeIDE/workspace_1.16.0/RoundLCD-SDRAM/Debug/…/Core/Src/lvgl_port_display.c:57: undefined reference to `lv_display_get_buf_active’
C:/ST/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/…/lib/gcc/arm-none-eabi/12.3.1/…/…/…/…/arm-none-eabi/bin/ld.exe: C:/Users/emre2/STM32CubeIDE/workspace_1.16.0/RoundLCD-SDRAM/Debug/…/Core/Src/lvgl_port_display.c:59: undefined reference to `lv_display_flush_ready’
C:/ST/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/…/lib/gcc/arm-none-eabi/12.3.1/…/…/…/…/arm-none-eabi/bin/ld.exe: ./Core/Src/lvgl_port_display.o: in function `lvgl_display_init’:
C:/Users/emre2/STM32CubeIDE/workspace_1.16.0/RoundLCD-SDRAM/Debug/…/Core/Src/lvgl_port_display.c:34: undefined reference to `lv_display_create’
C:/ST/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/…/lib/gcc/arm-none-eabi/12.3.1/…/…/…/…/arm-none-eabi/bin/ld.exe: C:/Users/emre2/STM32CubeIDE/workspace_1.16.0/RoundLCD-SDRAM/Debug/…/Core/Src/lvgl_port_display.c:36: undefined reference to `lv_display_set_buffers’
C:/ST/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/…/lib/gcc/arm-none-eabi/12.3.1/…/…/…/…/arm-none-eabi/bin/ld.exe: C:/Users/emre2/STM32CubeIDE/workspace_1.16.0/RoundLCD-SDRAM/Debug/…/Core/Src/lvgl_port_display.c:39: undefined reference to `lv_display_set_flush_cb’
C:/ST/STM32CubeIDE_1.16.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.12.3.rel1.win32_1.0.200.202406191623/tools/bin/…/lib/gcc/arm-none-eabi/12.3.1/…/…/…/…/arm-none-eabi/bin/ld.exe: ./Core/Src/stm32h7xx_it.o: in function `SysTick_Handler’:
C:/Users/emre2/STM32CubeIDE/workspace_1.16.0/RoundLCD-SDRAM/Debug/…/Core/Src/stm32h7xx_it.c:194: undefined reference to `lv_tick_inc’
collect2.exe: error: ld returned 1 exit status
make: *** [makefile:96: RoundLCD-SDRAM.elf] Error 1
“make -j32 all” terminated with exit code 2. Build might be incomplete.
What did I forget ?
