Lvgl on STM32F407VE Black with mbed
Porting to STM32F407VE ‘Black’ board
STM32F407VE with 3.2" TFT and ILI9341 driver, mbed-os5 with gcc
Graphics for some controller devices
followed the porting instructions, demo is running and displayed, touch is not yet implemented
Question:
init: I have used the port template and renamed it, my calls in main look like:
    lv_port_disp_init();
	//lv_tutorial_hello_world();
    demo_create();
is it the correct order? Or is there an test app that includes the enabled tests/demo/tutorials by the defines in the config file?
I’m using mbed which is an RTOS. What is all done in the lv_task_handler() ? I guess its better to call it in a task, will it be save when another tasks changes the screen contents? Do you have an idea how much stack is used in the handler?
And mbed has a C++ API, I would prefer that the graphics lib is also using C++. Is there already a C++ wrapper in work by someone?
Thanks for this great stuff!
lv_task_handler:
  • Checks for input from an input device (e.g. a touchscreen).
  • Refreshes the invalidated areas of the screen.
  • Calls any custom LittlevGL tasks you register with lv_task_create.
Have a look at the relevant part of the documentation.
It depends on the architecture and the application, so I would start with budgeting something like 4 kilobytes and then optimizing it later based on actual stack usage. That way you don’t run the risk of overflowing it later and having to spend hours debugging memory corruption. :slightly_smiling_face:
(In all of my projects, I’ve usually just left it at 4 kilobytes, as I have the memory to do so.)
Yes; that’s correct.
Not that I’m aware of (unless @rohmer wrote one as part of the UI designer he is making, but I doubt it).
thanks for the fast replay, will check more documentation.
About C++ wrapper, google found this for me:
not very complete, but some starting point. I think also for a gui designer its easier to deal with objects, but I’m at the beginning of testing lvgl and so its ok for now.
