New LVGL user here.
I have been doing some performance tests of the library to assess suitability for a project.
Target hardware is a ARM Linux Module, A7 Quad Core 1.2GHz, 24bit RGB 720x720 Display, 512mb RAM.
To start I built my base buildroot image (Linux 6.6.30) along with the SDK and built the LVGL Benchmark application: Quick Setup - LVGL 9.4 documentation
I configured to use FBDEV as this seems to be the most performant and most developed display driver in LVGL - I wanted to try/compare DRM direct, however there are build/linker issues that I need to resolve for this to work.
After some tweaking of parameters, CPU resources etc, I was able to successfully run the benchmark:
# lvgl-app
Benchmark Summary (9.3.0 dev)
Name, Avg. CPU, Avg. FPS, Avg. time, render time, flush time
Empty screen, 16%, 23, 6, 3, 3
Moving wallpaper, 78%, 28, 29, 26, 3
Single rectangle, 24%, 26, 7, 4, 3
Multiple rectangles, 27%, 28, 9, 6, 3
Multiple RGB images, 57%, 26, 21, 18, 3
Multiple ARGB images, 58%, 27, 20, 17, 3
Rotated ARGB images, 96%, 10, 93, 90, 3
Multiple labels, 39%, 26, 11, 8, 3
Screen sized text, 11%, 27, 30, 27, 3
Multiple arcs, 26%, 27, 9, 6, 3
Containers, 55%, 27, 19, 16, 3
Containers with overlay, 96%, 17, 55, 52, 3
Containers with opa, 99%, 26, 36, 33, 3
Containers with opa_layer, 100%, 21, 43, 40, 3
Containers with scrolling, 74%, 27, 25, 22, 3
Widgets demo, 93%, 27, 27, 24, 3
All scenes avg.,59%, 24, 27, 24, 3
As you can see, where the single CPU thread is taxed the frame redraw time, and the frame flush time, start to pull down the FPS (as expected). It’s clear in some drawing operations I am CPU Limited (software alpha blending - as expected).
However, there are several tests where the frame draw and frame flush should result in SIGNIFICANTLY higher FPS - e.g. Multiple Arcs has a total processing time of 10ms, so should result in a FPS of ~100.
Just a sidebar here, I also enabled the on-screen perfmon:
lv_display_t * disp = lv_display_get_default();
lv_sysmon_show_performance(disp);
For these tests, it show more or less a steady 30fps, so there is some variance here in the reported benchmark results.
Regardless, its clear there is some artificial cap on the FPS - for which I cannot determine.
The hardware is clearly capable - as:
- The display/hardware RGB Pixel Clock is sets refresh of 60Hz
- Running a different test (e.g. DirectFB2 df_andi) results in a flat 60FPS rate - basically capped a the hardware capability limit of the timing controller.
Things I have tried:
in lv_conf.h
/*Driver for /dev/fb*/
#define LV_USE_LINUX_FBDEV 1
#if LV_USE_LINUX_FBDEV
#define LV_LINUX_FBDEV_BSD 0
#define LV_LINUX_FBDEV_RENDER_MODE LV_DISPLAY_RENDER_MODE_FULL
#define LV_LINUX_FBDEV_BUFFER_COUNT 1
#define LV_LINUX_FBDEV_BUFFER_SIZE 518400
Changing buffer size, count and render mode (various options) - no appreciable result change.
My initial thought is that two buffers were interacting in some strange bug, but that doesn’t seem to make any difference if its 1 or 2.
in the core application (demo_app.c):
either:
v_task_handler();
usleep(1000);
or
lv_timer_handler_run_in_period(5);
changing the sleep or period in either of these functions also makes no difference, and these are now significantly quicker than the lowest draw+flush time on the demo as run.
It seems to me there is some other sort of interaction here which is capping performance. However, I cannot figure it out.
I have seen some other topics where people with “similar” hardware/cpu combos have achieved FPS > 30.
I can’t see/find any other user configurable areas which might impact this, hoping there is someone with experience that might be able to help me here.
