A screen with a top label 2 textareas with a corresponding label
when a textarea is focused or clicked, the keyboard should appear and be navigatable
currently, the keyboard appears and hides correctly, but no key can be selected and pressed
lvgl 9.1 with micropython on ESP32S3 with 296x240 SPI LCD
indev configured as KEYPAD with ENTER/ESC/PREV/NEXT/HOME/END/RIGHT/LEFT/UP/DOWN
v9.1
on-screen keyboard use with keypad to insert text into textarea
I tried setting the keyboard focused in the textarea CLICKED event callback
self._kb.send_event(lv.EVENT.FOCUSED, self._kb)
I used the online simulator with this code
https://sim.lvgl.io/v9.0/micropython/ports/webassembly/index.html
# Initialize
import display_driver
import lvgl as lv
disp = lv.display_get_default()
disp.set_resolution(296,240)
class TextArea:
def __init__(self, screen):
self._screen = screen
self.ta = lv.textarea(screen)
self.ta.add_event_cb(self._ta_event_cb, lv.EVENT.ALL, None)
self._kb = None
def _ta_event_cb(self, event):
code = event.get_code()
if code == lv.EVENT.CLICKED or code == lv.EVENT.FOCUSED:
if self._kb is None:
# create keyboard
self._kb = lv.keyboard(self._screen)
self._kb.set_size(self._screen.get_width(), int(self._screen.get_height()/2) )
self._kb.align_to(self.ta, lv.ALIGN.OUT_BOTTOM_MID, 0, 0)
self._kb.set_x(0)
self._kb.set_textarea(self.ta)
self._kb.add_event_cb(self._kb_event_cb, lv.EVENT.ALL, None)
elif code == lv.EVENT.DEFOCUSED:
if self._kb is not None:
self._kb.delete()
self._kb = None
def _kb_event_cb(self, event):
if code == lv.EVENT.READY or code == lv.EVENT.CANCEL:
self.ta.send_event(lv.EVENT.DEFOCUSED, self.ta)
class ButtonLabel:
def __init__(self, screen, label, cb):
btn = lv.button(screen)
self.btn = btn
btn.set_height(30)
lbl = lv.label(btn)
lbl.set_text(label)
lbl.align(lv.ALIGN.CENTER, 0, 0)
btn.add_event_cb(self._bt_event_cb, lv.EVENT.CLICKED, None)
self.cb = cb
def _bt_event_cb(self, event):
# code = event.get_code()
self.cb()
class WifiScreen:
def __init__(self):
self._screen = lv.obj()
self._construct()
def load(self):
lv.screen_load(self._screen)
def _save_cb(self):
ssid = self.ss_ta.ta.get_text()
key = self.key_ta.ta.get_text()
print(f"{ssid=}, {key=}")
# TODO save
def _cancel_cb(self):
print("Cancel")
#home_screen = fri3d.screens.home.HomeScreen()
#home_screen.load()
def _construct(self):
screen = self._screen
# title
title = lv.label(screen)
title.set_text("Wifi Configuration")
title.align(lv.ALIGN.TOP_MID, 0, 0)
# ssid textarea
ss_ta = TextArea(screen)
self.ss_ta = ss_ta
ss_ta.ta.set_text("")
ss_ta.ta.set_one_line(True)
ss_ta.ta.set_width(lv.pct(50))
ss_ta.ta.set_pos(100, 20)
# ssid label
ss_lbl = lv.label(screen)
ss_lbl.set_text("SSID:")
ss_lbl.align_to(ss_ta.ta, lv.ALIGN.OUT_LEFT_MID, -5, 0)
# key textarea
key_ta = TextArea(screen)
self.key_ta = key_ta
key_ta.ta.set_text("")
key_ta.ta.set_password_mode(True)
key_ta.ta.set_one_line(True)
key_ta.ta.set_width(lv.pct(50))
key_ta.ta.set_pos(100, 60)
# key label
key_lbl = lv.label(screen)
key_lbl.set_text("Key:")
key_lbl.align_to(key_ta.ta, lv.ALIGN.OUT_LEFT_MID, -5, 0)
# save button
sv = ButtonLabel(screen, lv.SYMBOL.OK + " Save", self._save_cb)
sv.btn.align(lv.ALIGN.RIGHT_MID, -5, 0)
# cancel button
cancel = ButtonLabel(screen, lv.SYMBOL.CLOSE + " Cancel", self._cancel_cb)
cancel.btn.align(lv.ALIGN.LEFT_MID, 5, 0)
w = WifiScreen()
w.load()
indev is created like this
indev_drv = lv.indev_create()
indev_drv.set_type(lv.INDEV_TYPE.KEYPAD)
indev_drv.set_read_cb(read_buttons)
indev_drv.set_display(lv.display_get_default())
grp = lv.group_create()
grp.set_default()
indev_drv.set_group(grp)
indev_drv.enable(True)
