I am working with K210 module and using the CanMV IDE usingmicropython
lvgl little
t make images from the camera be show in a GUI frame created
I tried coding but it does not work
class Frame:
def __init__(self, parent):
# Create a frame object inside the parent tab
self.frame_obj = lv.obj(parent)
self.frame_obj.set_size(220, 220)
self.frame_obj.align(parent, lv.ALIGN.CENTER, 0, 0)
# Initialize the camera (GC2145 sensor)
sensor.reset()
sensor.set_pixformat(sensor.RGB565) # Set color format (RGB565 for LCD compatibility)
sensor.set_framesize(sensor.QVGA) # 320x240 resolution
sensor.skip_frames(time=2000) # Let the camera adjust
# Create an LVGL image object inside the frame
self.img_display = lv.img(self.frame_obj)
self.img_display.set_size(220, 220)
self.img_display.align(self.frame_obj, lv.ALIGN.CENTER, 0, 0)
# Create an LVGL image descriptor
self.img_dsc = lv.img_dsc_t()
self.img_dsc.header.always_zero = 0
self.img_dsc.header.cf = lv.img.CF.TRUE_COLOR
self.img_dsc.header.w = 320
self.img_dsc.header.h = 240
self.img_dsc.data_size = 320 * 240 * 2 # RGB565 (2 bytes per pixel)
self.img_dsc.data = bytearray(self.img_dsc.data_size) # Create a buffer
# Start a timer to update the frame regularly
self.timer = Timer(1)
self.timer.init(period=100, mode=Timer.PERIODIC, callback=self.update_frame)
def update_frame(self, t):
img = sensor.snapshot() # Capture an image from the camera
img_data = img.copy().to_bytes() # Convert to a properly formatted bytearray
# Update the LVGL image descriptor with new frame data
self.img_dsc.data = img_data # Assign the new image data
# Update LVGL display
self.img_display.set_src(self.img_dsc) # Set the updated image
self.img_display.invalidate() # Force LVGL to refresh the display
