- ATmel sam9m10
- I initialized lvgl and created a flush function but it does not work
(lv_task_handler () in main function, lv_tick_inc (5) on timer… but LCD does not work now)
I tried to output “call” to check the function of flush function but it didn’t work
I wonder what’s wrong with the initialization…
Please help me
and ```
tags:
void lv_init_m(void)
/*Initialize disp_buf
with the buffer(s) /
lv_disp_buf_init(&disp_buf, buf_1, buf_2, BOARD_LCD_WIDTHBOARD_LCD_HEIGHT);
lv_disp_drv_init(&disp_drv); /Basic initialization/
// disp_drv.hor_res = LV_HOR_RES_MAX;
// disp_drv.ver_res = LV_VER_RES_MAX;
disp_drv.buffer = &disp_buf; /Set an initialized buffer/
disp_drv.flush_cb = my_flush_cb; /Set a flush callback to draw to the display/
lv_disp_t * disp;
disp = lv_disp_drv_register(&disp_drv); /Register the driver and save the created display objects/
void my_flush_cb(lv_disp_drv_t * disp_drv, const lv_area_t * area, lv_color_t * color_p)
/The most simple case (but also the slowest) to put all pixels to the screen one-by-one/
int32_t x, y;
unsigned char pBuffer_myflush[BOARD_LCD_WIDTH * BOARD_LCD_HEIGHT];
for(x = area->x1; x <= area->x2; x++){
LCDD_DrawPixel(pBuffer_myflush,x, y, (unsigned int)color_p);
color_p++;
dbgu_printf("call");
LCDD_DisplayBuffer(pBuffer_myflush);
/* IMPORTANT!!!
