I’m trying to use LVGL to display simple text and background color in a zephyr app with nRF52832. The app compiles and runs, but nothing is displayed on the screen. I’ve tried configuring the board file (.dts) and the prj.conf file. What am I missing? Is there any setting I need to make in the board file?
MCU: nRF52832, Framework: Zephyr
Use LVGL in Zephyr application and nRF52832 to display simple text.
- Added configuration in prj.conf
CONFIG_LV_Z_MEM_POOL_SIZE=16384
CONFIG_LV_Z_SHELL=y
CONFIG_MAIN_STACK_SIZE=2048
CONFIG_DISPLAY=y
CONFIG_DISPLAY_LOG_LEVEL_ERR=y
CONFIG_LVGL=y
CONFIG_LV_MEM_CUSTOM=y
CONFIG_LV_USE_LOG=y
CONFIG_LV_USE_LABEL=y
CONFIG_LV_USE_BTN=y
CONFIG_LV_USE_ARC=y
CONFIG_LV_USE_IMG=y
CONFIG_LV_USE_MONKEY=y
CONFIG_LV_FONT_MONTSERRAT_14=y
- Added display node in MIPI-DBI
chosen {
zephyr,display = &display;
mipi_dbi {
compatible = "zephyr,mipi-dbi-spi";
reset-gpios = <&gpio0 31 GPIO_ACTIVE_LOW>;
dc-gpios = <&gpio0 27 GPIO_ACTIVE_HIGH>;
spi-dev = <&spi0>;
write-only;
#address-cells = <1>;
#size-cells = <0>;
display: st7789v@0 {
compatible = "sitronix,st7789v";
mipi-max-frequency = <8000000>;
reg = <0>;
width = <240>;
height = <240>;
x-offset = <0>;
y-offset = <0>;
vcom = <0x19>;
gctrl = <0x35>;
vrhs = <0x12>;
vdvs = <0x20>;
mdac = <0x60>;
gamma = <0x01>;
colmod = <0x55>;
lcm = <0x2c>;
porch-param = [0c 0c 00 33 33];
cmd2en-param = [5a 69 02 01];
pwctrl1-param = [a4 a1];
pvgam-param = [d0 04 0d 11 13 2b 3f 54 4c 18 0d 0b 1f 23];
nvgam-param = [d0 04 0c 11 13 2c 3f 44 51 2f 1f 1f 20 23];
ram-param = [00 f0];
rgb-param = [cd 08 14];
mipi-mode = <MIPI_DBI_MODE_SPI_4WIRE>;
status = "okay";
&pinctrl {
spi0_default: spi0_default {
group1 {
psels = <NRF_PSEL(SPIM_MOSI, 0, 29)>, <NRF_PSEL(SPIM_SCK, 0, 28)>;
low-power-enable;
&spi0 {
status = "okay";
pinctrl-0 = <&spi0_default>;
pinctrl-names = "default";
cs-gpios = <&gpio0 30 0>;
void hello_world()
LOG_INF("Starting LVGL thread");
char count_str[11] = {0};
const struct device *display_dev;
lv_obj_t *hello_world_label;
lv_obj_t *count_label;
display_dev = DEVICE_DT_GET(DT_CHOSEN(zephyr_display));
if (!device_is_ready(display_dev))
LOG_ERR("Display device not ready");
return;
lv_obj_t *screen = lv_scr_act();
lv_obj_set_style_bg_color(screen, lv_color_white(), LV_PART_MAIN);
lv_obj_set_style_bg_opa(screen, LV_OPA_COVER, LV_PART_MAIN);
hello_world_label = lv_label_create(screen);
lv_label_set_text(hello_world_label, "Hello world!");
lv_obj_set_style_text_color(hello_world_label, lv_color_black(), LV_PART_MAIN);
lv_obj_align(hello_world_label, LV_ALIGN_CENTER, 0, 0);
count_label = lv_label_create(screen);
lv_obj_set_style_text_color(count_label, lv_color_black(), LV_PART_MAIN);
lv_obj_align(count_label, LV_ALIGN_BOTTOM_MID, 0, 0);
display_blanking_off(display_dev);
lv_task_handler();
while (1)
if ((count % 100) == 0U)
sprintf(count_str, "%d", count / 100U);
lv_label_set_text(count_label, count_str);
lv_task_handler();
++count;
k_msleep(10);
