I needed help with just one more thing.
I’m trying to implement a test I made in Squareline Studio but the UI isn’t starting and the screen stays white. Maybe someone could help me, this is my code.
I can run the demos but I can’t implement it created by me
I have esp32 8048s070
#include <lvgl.h>
#include “ui.h”
#include “Arduino.h”
#include <TAMC_GT911.h>
#define TOUCH_SCL 20
#define TOUCH_SDA 19
#define TOUCH_INT -1
#define TOUCH_RST 38
#define TOUCH_ROTATION ROTATION_NORMAL
#define TOUCH_MAP_X2 0
#define TOUCH_MAP_X1 800
#define TOUCH_MAP_Y2 480
#define TOUCH_MAP_Y1 0
//---- TFT Set ------------------------------------------
#define GFX_BL 2
// 7"
Arduino_ESP32RGBPanel rgbpanel = new Arduino_ESP32RGBPanel(
41 / DE /, 40 / VSYNC /, 39 / HSYNC /, 42 / PCLK /,
14 / R0 /, 21 / R1 /, 47 / R2 /, 48 / R3 /, 45 / R4 /,
9 / G0 /, 46 / G1 /, 3 / G2 /, 8 / G3 /, 16 / G4 /, 1 / G5 /,
15 / B0 /, 7 / B1 /, 6 / B2 /, 5 / B3 /, 4 / B4 /,
0 / hsync_polarity /, 180 / hsync_front_porch /, 30 / hsync_pulse_width /, 16 / hsync_back_porch /,
0 / vsync_polarity /, 12 / vsync_front_porch /, 13 / vsync_pulse_width /, 10 / vsync_back_porch */);
Arduino_RGB_Display gfx = new Arduino_RGB_Display(
800 / width /, 480 / height /, rgbpanel, 0 / rotation /, true / auto_flush */);
int touch_last_x = 0;
int touch_last_y = 0;
TAMC_GT911 ts = TAMC_GT911(TOUCH_SDA, TOUCH_SCL, TOUCH_INT, TOUCH_RST, max(TOUCH_MAP_X1, TOUCH_MAP_X2), max(TOUCH_MAP_Y1, TOUCH_MAP_Y2));
//---- Funções de Inicialização --------------------------------------------------
void tft_init() {
// Inicializa o display TFT
gfx->begin();
gfx->fillScreen(0xFFFF); // white
Serial.println(“TFT initialized”);
void touch_init() {
// Inicializa o touch screen
ts.begin(); // Inicializa o touch screen
Serial.println(“Touch initialized”); // Confirma a inicialização
//---- Main --------------------------------------------------
void setup() {
Serial.begin(115200);
pinMode(GFX_BL, OUTPUT); // Define o pino de controle da luz de fundo como saída
digitalWrite(GFX_BL, HIGH);
delay(10); // Espera 10ms para a luz de fundo estabilizar
tft_init(); // Inicializa o TFT
touch_init(); // Inicializa o touch screen
// Chama a função para inicializar a interface gerada pelo SquareLine Studio
ui_init();
Serial.println(“Setup done”);
void loop() {
lv_timer_handler(); /* Deixa o GUI fazer seu trabalho */
delay(5);
