Hi! Im trying to do an OS with LVGL, but when im connecting to wifi or checking for updates it’s freezing for a few seconds before comming back normal. I’ve read the docs and found that LVGL IS NOT THREAD-SAFE. If someone can help me by adding gateway-threads into my project will be appreciated.
Arduino Nano ESP32 (ESP32 S3)
9.2.2
LVGL not freezing anymore
MUTEX but is not working (for me)
#include <WiFi.h>
#include <WebServer.h>
#include <ESPmDNS.h>
#include <Update.h>
#include <HTTPClient.h>
#include <WiFiClientSecure.h>
#include <lvgl.h>
#include <ui.h>
#include <vector>
#include "time.h"
const char *ntpServer = "pool.ntp.org";
const long gmtOffset_sec = +2 * 60 * 60; // Set your timezone here
const int daylightOffset_sec = +3 * 60 * 60;
#include <EEPROM.h>
#define EEPROM_SIZE 128
#define EEPROM_ADDR_WIFI_FLAG 0
#define EEPROM_ADDR_WIFI_CREDENTIAL 4
typedef enum {
NONE,
NETWORK_SEARCHING,
NETWORK_CONNECTED_POPUP,
NETWORK_CONNECTED,
NETWORK_CONNECT_FAILED
} Network_Status_t;
Network_Status_t networkStatus = NONE;
const char *version_url = "https://raw.githubusercontent.com/IT-Generation-Monq/Update-Test/main/version.txt"; // Path to the version.txt file
const char *changelog_url = "https://raw.githubusercontent.com/IT-Generation-Monq/Update-Test/main/changelog.txt"; // Path to the changelog.txt file
String firmware_url = "https://raw.githubusercontent.com/IT-Generation-Monq/Update-Test/main/firmware_vX.X.X.bin"; // Path to the firmware file
String LVGL_Arduino = String("LVGL Version: ") + lv_version_major() + "." + lv_version_minor() + "." + lv_version_patch();
// GitHub version and firmware URLs
String current_version = "0.0.1"; // Current firmware version
String new_version_changelog;
String new_version;
WebServer server(80); // Web server for OTA Web Updater
WiFiClientSecure client;
#include <LovyanGFX.hpp>
class LGFX : public lgfx::LGFX_Device {
lgfx::Panel_ILI9488 _panel_instance;
lgfx::Bus_SPI _bus_instance;
lgfx::Light_PWM _light_instance;
lgfx::Touch_FT5x06 _touch_instance;
public:
LGFX(void) {
auto cfg = _bus_instance.config();
cfg.spi_host = SPI3_HOST;
cfg.spi_mode = 0;
cfg.freq_write = 40000000;
cfg.freq_read = 16000000;
cfg.spi_3wire = false;
cfg.use_lock = true;
cfg.dma_channel = SPI_DMA_CH_AUTO;
cfg.pin_sclk = 48;
cfg.pin_mosi = 38;
cfg.pin_miso = 47;
cfg.pin_dc = 2;
// If you use a common SPI bus with the SD card, be sure to set MISO and do not omit it.
_bus_instance.config(cfg);
_panel_instance.setBus(&_bus_instance);
auto cfg = _panel_instance.config();
cfg.pin_cs = 14;
cfg.pin_rst = 4;
cfg.pin_busy = -1;
cfg.panel_width = 320;
cfg.panel_height = 480;
cfg.offset_x = 0;
cfg.offset_y = 0;
cfg.offset_rotation = 0;
cfg.dummy_read_pixel = 8;
cfg.dummy_read_bits = 1;
cfg.readable = true;
cfg.invert = true;
cfg.rgb_order = false;
cfg.dlen_16bit = false;
cfg.bus_shared = true; // If the bus is shared with the SD card, set it to true (bus control is performed using drawJpgFile, etc.)
_panel_instance.config(cfg);
auto cfg = _light_instance.config();
cfg.pin_bl = 13;
cfg.invert = true;
cfg.freq = 44100;
cfg.pwm_channel = 7;
_light_instance.config(cfg);
_panel_instance.setLight(&_light_instance);
auto cfg = _touch_instance.config();
cfg.x_min = 0;
cfg.x_max = 319;
cfg.y_min = 0;
cfg.y_max = 479;
cfg.pin_int = 21;
cfg.i2c_port = 1;
cfg.i2c_addr = 0x38;
cfg.pin_sda = 11;
cfg.pin_scl = 12;
cfg.freq = 400000;
_touch_instance.config(cfg);
_panel_instance.setTouch(&_touch_instance);
setPanel(&_panel_instance);
LGFX tft;
static const uint16_t screenWidth = 320;
static const uint16_t screenHeight = 480;
enum { SCREENBUFFER_SIZE_PIXELS = screenWidth * screenHeight / 10 };
static lv_color_t buf[SCREENBUFFER_SIZE_PIXELS];
#if LV_USE_LOG != 0
/* Serial debugging */
void my_print(const char *buf) {
Serial.printf(buf);
Serial.flush();
/* Display flushing */
void my_disp_flush(lv_display_t *disp, const lv_area_t *area, uint8_t *pixelmap) {
if (LV_COLOR_16_SWAP) {
size_t len = lv_area_get_size(area);
lv_draw_sw_rgb565_swap(pixelmap, len);
tft.startWrite();
tft.pushColors((uint16_t *)pixelmap, w * h, true);
tft.endWrite();
lv_disp_flush_ready(disp);
/*Read the touchpad*/
void my_touchpad_read(lv_indev_t *indev_driver, lv_indev_data_t *data) {
uint16_t touchX = 0, touchY = 0;
bool touched = tft.getTouch(&touchX, &touchY);
if (!touched) {
} else {
/*Set the coordinates*/
data->point.x = touchX;
data->point.y = touchY;
//Serial.print( "Data x " );
//Serial.println( touchX );
//Serial.print( "Data y " );
//Serial.println( touchY );
/*Set tick routine needed for LVGL internal timings*/
static uint32_t my_tick_get_cb(void) {
return millis();
static lv_timer_t *timer;
static int foundNetworks = 0;
unsigned long networkTimeout = 10 * 1000;
String ssidName, ssidPW;
TaskHandle_t ntScanTaskHandler, ntConnectTaskHandler;
std::vector<String> foundWifiList;
void setup() {
Serial.begin(115200);
delay(100);
#if LV_USE_LOG != 0
lv_log_register_print_cb(my_print); /* register print function for debugging */
tft.begin(); /* TFT init */
tft.setRotation(0); /* Landscape orientation, flipped */
tft.setBrightness(0);
uint16_t calData[] = { 0, 0, 0, 479, 319, 0, 319, 479 };
tft.setTouchCalibrate(calData);
static lv_disp_t *disp;
disp = lv_display_create(screenWidth, screenHeight);
lv_display_set_buffers(disp, buf, NULL, SCREENBUFFER_SIZE_PIXELS * sizeof(lv_color_t), LV_DISPLAY_RENDER_MODE_PARTIAL);
static lv_indev_t *indev;
indev = lv_indev_create();
lv_indev_set_read_cb(indev, my_touchpad_read);
lv_tick_set_cb(my_tick_get_cb);
ui_init();
listCurrentVersion();
//tryPreviousNetwork();
/*WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println("\nWiFi connected");*/
void loop() {
lv_task_handler(); // let the GUI do its work
//delay(5);
if (!WiFi.status() == WL_CONNECTED) {
} else {
server.handleClient();
//server.handleClient(); // Handle web updater requests
//delay(1000);
// Check for OTA updates on GitHub once at startup
/*if (checkForUpdate(firmware_url)) {
performOTA(firmware_url.c_str());
delay(1000);*/
void tryPreviousNetwork() {
if (!EEPROM.begin(EEPROM_SIZE)) {
delay(1000);
ESP.restart();
loadWIFICredentialEEPROM();
void saveWIFICredentialEEPROM(int flag, String ssidpw) {
EEPROM.writeInt(EEPROM_ADDR_WIFI_FLAG, flag);
EEPROM.writeString(EEPROM_ADDR_WIFI_CREDENTIAL, flag == 1 ? ssidpw : "");
EEPROM.commit();
void loadWIFICredentialEEPROM() {
int wifiFlag = EEPROM.readInt(EEPROM_ADDR_WIFI_FLAG);
String wifiCredential = EEPROM.readString(EEPROM_ADDR_WIFI_CREDENTIAL);
if (wifiFlag == 1 && wifiCredential.length() != 0 && wifiCredential.indexOf(" ") != -1) {
char preSSIDName[30], preSSIDPw[30];
if (sscanf(wifiCredential.c_str(), "%s %s", preSSIDName, preSSIDPw) == 2) {
lv_obj_add_state(ui_Switch1, LV_STATE_CHECKED);
lv_obj_send_event(ui_Switch1, LV_EVENT_VALUE_CHANGED, NULL);
ssidName = String(preSSIDName);
ssidPW = String(preSSIDPw);
networkConnector();
} else {
saveWIFICredentialEEPROM(0, "");
void ui_event_Switch1(lv_event_t *e) {
lv_obj_t *btn = (lv_obj_t *)lv_event_get_target(e);
if (code == LV_EVENT_CLICKED) {
if (btn == ui_Button7) {
ssidPW = String(lv_textarea_get_text(ui_TextArea1));
networkConnector();
lv_obj_add_flag(ui_Panel19, LV_OBJ_FLAG_HIDDEN);
lv_obj_remove_flag(ui_Panel20, LV_OBJ_FLAG_HIDDEN);
} else if (btn == ui_Button6) {
lv_obj_add_flag(ui_Panel17, LV_OBJ_FLAG_HIDDEN);
} else if (code == LV_EVENT_VALUE_CHANGED) {
_ui_flag_modify(ui_Label23, LV_OBJ_FLAG_HIDDEN, _UI_MODIFY_FLAG_TOGGLE);
if (btn == ui_Switch1) {
if (lv_obj_has_state(btn, LV_STATE_CHECKED)) {
if (ntScanTaskHandler == NULL) {
networkStatus = NETWORK_SEARCHING;
networkScanner();
timer = lv_timer_create(timerForNetwork, 1000, ui_Panel16);
//lv_list_add_text(wfList, "WiFi: Looking for Networks...");
} else {
if (ntScanTaskHandler != NULL) {
vTaskDelete(ntScanTaskHandler);
ntScanTaskHandler = NULL;
lv_timer_del(timer);
lv_obj_clean(ui_Panel16);
if (WiFi.status() == WL_CONNECTED) {
WiFi.disconnect(true);
lv_label_set_text(ui_Label12, "");
lv_label_set_text(ui_Label17, "");
//lv_label_set_text(timeLabel, "WiFi Not Connected! " LV_SYMBOL_CLOSE);
static void timerForNetwork(lv_timer_t *timer) {
LV_UNUSED(timer);
switch (networkStatus) {
case NETWORK_SEARCHING:
showingFoundWiFiList();
break;
case NETWORK_CONNECTED_POPUP:
lv_obj_remove_flag(ui_Panel21, LV_OBJ_FLAG_HIDDEN);
networkStatus = NETWORK_CONNECTED;
configTime(gmtOffset_sec, daylightOffset_sec, ntpServer);
break;
case NETWORK_CONNECTED:
lv_label_set_text_fmt(ui_Label34, "%s", ssidName.c_str());
lv_label_set_text_fmt(ui_Label47, "%s", ssidName.c_str());
lv_label_set_text(ui_Label12, LV_SYMBOL_WIFI);
lv_label_set_text(ui_Label17, LV_SYMBOL_WIFI);
updateLocalTime();
break;
case NETWORK_CONNECT_FAILED:
lv_obj_remove_flag(ui_Panel22, LV_OBJ_FLAG_HIDDEN);
break;
default:
break;
static void showingFoundWiFiList() {
if (foundWifiList.size() == 0 || foundNetworks == foundWifiList.size())
return;
//lv_list_add_text(ui_Panel16, foundWifiList.size() > 1 ? "WiFi: Found Networks" : "WiFi: Not Found!");
for (std::vector<String>::iterator item = foundWifiList.begin(); item != foundWifiList.end(); ++item) {
lv_obj_t *btn = lv_list_add_btn(ui_Panel16, LV_SYMBOL_WIFI, (*item).c_str());
lv_obj_add_event_cb(btn, list_event_handler, LV_EVENT_CLICKED, NULL);
lv_obj_set_style_text_font(btn, &lv_font_montserrat_16, LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_set_style_bg_color(btn, lv_color_hex(0x000000), LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_set_style_bg_opa(btn, 255, LV_PART_MAIN | LV_STATE_DEFAULT);
delay(1);
foundNetworks = foundWifiList.size();
static void list_event_handler(lv_event_t *e) {
lv_obj_t *obj = (lv_obj_t *)lv_event_get_target(e);
String selectedItem = String(lv_list_get_btn_text(ui_Panel16, obj));
for (int i = 0; i < selectedItem.length() - 1; i++) {
if (selectedItem.substring(i, i + 2) == " (") {
ssidName = selectedItem.substring(0, i);
lv_label_set_text_fmt(ui_Label26, "%s", ssidName.c_str());
lv_obj_remove_flag(ui_Panel17, LV_OBJ_FLAG_HIDDEN);
lv_obj_remove_flag(ui_Panel19, LV_OBJ_FLAG_HIDDEN);
break;
* NETWORK TASKS
static void networkScanner() {
xTaskCreate(scanWIFITask,
"ScanWIFITask",
4096,
NULL,
1,
&ntScanTaskHandler);
static void networkConnector() {
xTaskCreate(beginWIFITask,
"beginWIFITask",
2048,
NULL,
1,
&ntConnectTaskHandler);
static void scanWIFITask(void *pvParameters) {
while (1) {
foundWifiList.clear();
int n = WiFi.scanNetworks();
vTaskDelay(10);
for (int i = 0; i < n; ++i) {
String item = WiFi.SSID(i) + " (" + WiFi.RSSI(i) + ") " + ((WiFi.encryptionType(i) == WIFI_AUTH_OPEN) ? " " : "*");
foundWifiList.push_back(item);
vTaskDelay(10);
vTaskDelay(5000);
void beginWIFITask(void *pvParameters) {
unsigned long startingTime = millis();
WiFi.mode(WIFI_STA);
WiFi.disconnect();
vTaskDelay(100);
WiFi.begin(ssidName.c_str(), ssidPW.c_str());
while (WiFi.status() != WL_CONNECTED && (millis() - startingTime) < networkTimeout) {
vTaskDelay(250);
networkStatus = NETWORK_CONNECTED_POPUP;
saveWIFICredentialEEPROM(1, ssidName + " " + ssidPW);
if (MDNS.begin("esp32")) {
Serial.println("MDNS responder started");
client.setInsecure();
// Web Updater endpoints
server.on("/", HTTP_GET, []() {
server.sendHeader("Connection", "close");
server.send(200, "text/html", "<form method='POST' action='/update' enctype='multipart/form-data'><input type='file' name='update'><input type='submit' value='Update'></form>");
server.on(
"/update", HTTP_POST, []() {
server.send(200, "text/plain", (Update.hasError()) ? "FAIL" : "OK");
ESP.restart();
HTTPUpload &upload = server.upload();
if (upload.status == UPLOAD_FILE_START) {
Serial.printf("Update: %s\n", upload.filename.c_str());
if (!Update.begin(UPDATE_SIZE_UNKNOWN)) {
Update.printError(Serial);
} else if (upload.status == UPLOAD_FILE_WRITE) {
if (Update.write(upload.buf, upload.currentSize) != upload.currentSize) {
} else if (upload.status == UPLOAD_FILE_END) {
if (Update.end(true)) {
Serial.printf("Update Success: %u\nRebooting...\n", upload.totalSize);
} else {
server.begin();
} else {
networkStatus = NETWORK_CONNECT_FAILED;
vTaskDelete(NULL);
void updateLocalTime() {
struct tm timeinfo;
if (!getLocalTime(&timeinfo)) {
return;
char hourMin[6];
strftime(hourMin, 6, "%H:%M", &timeinfo);
String hourMinWithSymbol = String(hourMin);
//hourMinWithSymbol;
lv_label_set_text(ui_Label4, hourMinWithSymbol.c_str());
lv_label_set_text(ui_Label40, hourMinWithSymbol.c_str());
// Function to check for updates
bool checkForUpdate(String &firmware_url) {
HTTPClient http;
http.begin(version_url);
int httpCode = http.GET();
if (httpCode == HTTP_CODE_OK) {
new_version = http.getString();
new_version.trim();
Serial.println("Current version: " + current_version);
Serial.println("Available version: " + new_version);
if (new_version != current_version) {
Serial.println("New version available. Getting changelog...");
http.begin(changelog_url);
new_version_changelog = http.getString();
new_version_changelog.trim();
Serial.println("Changelog: ");
Serial.println(new_version_changelog);
/*Serial.println("Updating. Please wait...");
firmware_url = String("https://raw.githubusercontent.com/IT-Generation-Monq/Update-Test/main/firmware_v")+ new_version + String(".bin");
Serial.println("Firmware URL: " + firmware_url);*/
return true;
} else {
Serial.println("Already on the latest version");
lv_obj_remove_flag(ui_Label13, LV_OBJ_FLAG_HIDDEN);
} else {
Serial.println("Failed to check for update, HTTP code: " + String(httpCode));
http.end();
return false;
void performOTA(const char *firmware_url) {
HTTPClient http;
http.begin(firmware_url);
int contentLength = http.getSize();
bool canBegin = Update.begin(contentLength);
if (canBegin) {
size_t written = Update.writeStream(http.getStream());
if (written == contentLength) {
Serial.println("Written : " + String(written) + " successfully");
} else {
Serial.println("Written only : " + String(written) + "/" + String(contentLength) + ". Retry?");
if (Update.end()) {
Serial.println("OTA done!");
if (Update.isFinished()) {
Serial.println("Update successfully completed.");
lv_obj_remove_flag(ui_Panel8, LV_OBJ_FLAG_HIDDEN);
//delay(300);
//ESP.restart();
} else {
Serial.println("Update not finished? Something went wrong!");
} else {
Serial.println("Error Occurred. Error #: " + String(Update.getError()));
} else {
Serial.println("Not enough space to begin OTA");
} else {
Serial.println("Cannot download firmware. HTTP code: " + String(httpCode));
http.end();
void ui_event_Button1(lv_event_t *e) {
if (event_code == LV_EVENT_CLICKED) {
lv_obj_add_flag(ui_Panel9, LV_OBJ_FLAG_HIDDEN);
lv_obj_add_flag(ui_Panel14, LV_OBJ_FLAG_HIDDEN);
if (WiFi.status() != WL_CONNECTED) {
lv_obj_remove_flag(ui_Label18, LV_OBJ_FLAG_HIDDEN);
} else {
lv_obj_remove_flag(ui_Panel3, LV_OBJ_FLAG_HIDDEN);
lv_obj_remove_flag(ui_Panel9, LV_OBJ_FLAG_HIDDEN);
lv_label_set_text_fmt(ui_Label19, "Version: %s", new_version.c_str());
lv_label_set_text_fmt(ui_Label14, "Version: %s", new_version.c_str());
lv_label_set_text_fmt(ui_Label16, "%s", new_version_changelog.c_str());
lv_label_set_text_fmt(ui_Label39, "%s", new_version_changelog.c_str());
} else {
lv_obj_remove_flag(ui_Panel14, LV_OBJ_FLAG_HIDDEN);
void listCurrentVersion() {
lv_label_set_text_fmt(ui_Label5, "OS version: %s", current_version.c_str());
lv_label_set_text_fmt(ui_Label21, "OS version: %s", current_version.c_str());
lv_label_set_text_fmt(ui_Label53, "Version: %s", current_version.c_str());
lv_label_set_text_fmt(ui_Label6, "%s", LVGL_Arduino.c_str());
void ui_event_Button4(lv_event_t *e) {
_ui_screen_change(&ui_Screen2, LV_SCR_LOAD_ANIM_NONE, 0, 0, &ui_Screen2_screen_init);
firmware_url = String("https://raw.githubusercontent.com/IT-Generation-Monq/Update-Test/main/firmware_v") + new_version + String(".bin");
void ui_event_Button12(lv_event_t *e) {
ESP.restart();
