Lvgl_esp32_drivers compatibility
I the lvgl_esp32_drivers realy to use with lvgl release 8.3 and with esp-idf v5.0.1 version. It seems that it needs update cause several problems exists on build
you can check this for changes identified. It could be that it is not the proper way but at least it is some way to make initial build not to fail
You can use my repo if you like, I manage to compile up to the latest version, at least 2 weeks ago was compiling fine!!!.
https://github.com/artemisoftnian/lvgl_esp32_drivers
I was wondering if I can use your fork with latest lvgl and esp-idf versions. If not, what is the suggested version to build it?
