Lvgl error in code
Im getting this error error: 'ui' was not declared in this scope lv_label_set_text(ui.BGPOS, labelValue);
esp32
8.4
pass a value from the encoder to the label BGPOS
IVe entered the following code to pass the value to the BGPOS label to display, this is in ui.h
// Read the encoder position
int encoderPos = encoder.read() / 4; // Adjust for ppi (256) of the encoder
// Convert the encoder position to millimeters
float pitch = 100.0; // Pitch in millimeters per pulse
float encoderPos_mm = encoderPos * pitch;
// Update the label with the new position
char labelValue[16];
sprintf(labelValue, “BGPOS: %.1f mm”, encoderPos_mm);
I get `i\ui.ino:143:21: error: ‘ui’ was not declared in this scope
exit status 1
Compilation error: ‘ui’ was not declared in this scope`
