I created a test UI using the LVGL Editor. I want to call it from main.cpp.
The code compiles and uploads successfully, but nothing shows on the display. How to fix the issue ?
I tested the LVGL Hello World example, and it worked fine, it shows on the display.
Board: Elecrow CrowPanel ESP32 5.79”
LVGL Version: 9.2.0
#include <Arduino.h>
#include <SPI.h>
#include "EPD.h"
#include "EPD_Init.h"
#include "lvgl_setup.h"
#include "../lib/Test/ui.h"
void setup() {
// Initialize LVGL
lvgl_init();
// Initialize UI (generated by LVGL GUI Builder)
ui_init("");
Full code
#include <SPI.h>
#include "EPD.h"
// Buffer for the EPD
uint8_t ImageBW[27200];
void create_hello_world_ui(); // Forward declaration for the UI creation function
void setup() {
Serial.begin(115200);
Serial.println("EPD LVGL Hello World Starting...");
// Initialize EPD control pin (following factory demo)
pinMode(7, OUTPUT);
digitalWrite(7, HIGH);
// Initialize EPD hardware
EPD_GPIOInit();
Paint_NewImage(ImageBW, EPD_W, EPD_H, Rotation, WHITE);
Paint_Clear(WHITE);
// Fast mode initialization
EPD_FastMode1Init();
EPD_Display_Clear();
EPD_Update();
Serial.println("EPD initialized, starting LVGL...");
// Initialize LVGL
lvgl_init();
ui_init("");
// Create the UI
// create_hello_world_ui();
// Force LVGL to render
lv_timer_handler();
delay(10);
Serial.println("Updating display...");
// Re-initialize for display
EPD_GPIOInit();
// Display the rendered content
EPD_Display(ImageBW);
EPD_FastUpdate(); // Use FastUpdate
// Put display to sleep
EPD_DeepSleep();
Serial.println("Display update complete!");
void loop() {
// Static display - no updates needed
delay(1000);
void create_hello_world_ui() {
// Get the active screen
lv_obj_t *scr = lv_display_get_screen_active(epd_display);
// Clear screen to white
lv_obj_set_style_bg_color(scr, lv_color_white(), LV_PART_MAIN);
lv_obj_set_style_bg_opa(scr, LV_OPA_COVER, LV_PART_MAIN);
// Create a label for "Hello World"
lv_obj_t *hello_label = lv_label_create(scr);
lv_label_set_text(hello_label, "Hello World!");
// Style the label
lv_obj_set_style_text_color(hello_label, lv_color_black(), LV_PART_MAIN);
lv_obj_set_style_text_font(hello_label, &lv_font_montserrat_32, LV_PART_MAIN);
// Center the label on screen
lv_obj_align(hello_label, LV_ALIGN_CENTER, 0, -50);
// Create a second label with additional info
lv_obj_t *info_label = lv_label_create(scr);
lv_label_set_text(info_label, "LVGL on E-Paper");
// Style the info label
lv_obj_set_style_text_color(info_label, lv_color_black(), LV_PART_MAIN);
lv_obj_set_style_text_font(info_label, &lv_font_montserrat_16, LV_PART_MAIN);
// Position below the main label
lv_obj_align(info_label, LV_ALIGN_CENTER, 0, 0);
Thank you.
