lvGL C++ Wrapper
I’m Working on a C++ wrapper of the library.
At moment is in a very early stage but it works nicely.
if someone is interested in code i will share with community.
At moment i’m able to run applications on simulator and embedded linux platform using fbdev and event input interface.
code will be like:
int main (int argc,char** argv) {
GUI* App = new GUI();
App->Go();
App->Jo();
App->Kill();
return 0;
int GUI::AppInit() {
IO->enCursor();
CREATE_LV_EVENT(Btn_Pressed_lvcb,GUI,this,&GUI::Btn_Pressed_cb);
calendar = new lvCalendar();
calendar->EnableMultiSel();
calendar->SetDate(5,6,2021);
calendar->ShowToday();
calendar->Center();
calendar->DropDown(true);
lvButton* btn = new lvButton();
btn->SetLabel("Ciao");
btn->AlignParent(LV_ALIGN_BOTTOM_RIGHT,-10,-10);
btn->SetCallback(LV_EVENT_PRESSED,Btn_Pressed_lvcb);
return 0;
void GUI::Btn_Pressed_cb(void* btn) {
if(calendar)
calendar->DropDown(false);
you can find the code at GitHub - fstuff-dev/lvglpp: lvGL C++ Wrapper !!! let me know !!!
Great, I am interested to see, what you come up with ! Lot’s of things to consider I reckon. For instance you might have to write own allocators if you end up using smart pointers with move semantics.
Hi you can find the code at GitHub - fstuff-dev/lvglpp: lvGL C++ Wrapper !!! let me know !!!
That’s great! A C++ binding would add great value to LVGL. Are interested in working with us on an official C++ biding?
Yeah ! I Really love the library and i think that have a really great potential for embedded systems.
if you have suggestion on my code will be a grate starting point for the C++ Binding.
Let me Know if you like the code and if we can take some good from it.
Thanks
I think wrapper is a great idea, can’t wait to test it!
Maybe you could try to modify the micropython wrapper generator code to generate C++ wrapper automatically?
Great, thanks. I think there is a lot of things to discuss, such as:
  • how should the API look like
  • what C++ features to use
  • automatic code generation
  • manually added parts
  • how to keep track of the new features of LVGL
  • how and what kind of test shall we run to test the binding
I’ve opened an issue for it on GitHub. Let’s continue there :slight_smile:
  • etc
