Lvgl buttton program output needed
imx7D Colibri
v8.3
i need to create one simple button
last weel
when i go throught the documentation of lvgl i saw different different examples in that i took one button code from examples folder, there all are having code but not able to compile the where i have to button code for testing and let me know about makefile and process to get output of button
type or p#include "../../lv_examples.h"
#if LV_USE_BTN && LV_BUILD_EXAMPLES
static void event_handler(lv_event_t * e)
        LV_LOG_USER("Clicked");
    else if(code == LV_EVENT_VALUE_CHANGED) {
        LV_LOG_USER("Toggled");
void lv_example_btn_1(void)
    lv_obj_t * label;
    lv_obj_t * btn1 = lv_btn_create(lv_scr_act());
    lv_obj_add_event_cb(btn1, event_handler, LV_EVENT_ALL, NULL);
    lv_obj_align(btn1, LV_ALIGN_CENTER, 0, -40);
    label = lv_label_create(btn1);
    lv_obj_center(label);
    lv_obj_t * btn2 = lv_btn_create(lv_scr_act());
    lv_obj_add_event_cb(btn2, event_handler, LV_EVENT_ALL, NULL);
    lv_obj_align(btn2, LV_ALIGN_CENTER, 0, 40);
    lv_obj_add_flag(btn2, LV_OBJ_FLAG_CHECKABLE);
    lv_obj_set_height(btn2, LV_SIZE_CONTENT);
    label = lv_label_create(btn2);
    lv_label_set_text(label, "Toggle");
#endifaste code here
above code is available in button 1 program i need to get the output, what is the process i have to follow to get output and please provide the steps  as soon as possible
need zip file for button having toggle function
and display interface
Please attach the compiler log too.
