Lvgl build with vector graphic support
In LVGL 9 I wanted to try out the new vector graphic support. In the configuration I have leave everything at default except:
#define LV_USE_VECTOR_GRAPHIC 1
#define LV_USE_THORVG_INTERNAL 1
After this setup when building the project I get multiple errors:
undefined reference to `_imp__tvg_engine_init’
undefined reference to `_imp__tvg_engine_term’
The same errors goes on for every function.
Is there any documentation how to build this correctly or what could be wrong?
Windows, building with GCC
Danijel
I would try compiling under WSL. Windows can be a fickle animal even when using MINGW etal.
I think the problem is something else. I have now tried to build the project on a ubuntu machine and I receive just the same errors.
Any other idea?
I’m currently using Ubuntu and compiled the latest master with no errors (with lv_port_pc_eclipse). I’ve also searched for the symbols as tvg_engine_init and tvg_engine_term and they’re in tvgCapi.cpp, are you also compiling that file?
Any other clue on the environment you’re using? An specific IDE?
I have tried to build on windows with gcc and also an esp32 project inside espressif-ide, both failed. Then I tried also on a virtual ubuntu to build the esp32 project but failed as well. I get always the same error.
So for me now currently its mostly imporant that I will be also able to build the code for esp32.
I have checked the thorvg_capi.h where the dunction is declared and there is a macro TVG_API which I quiet dont underastant what makes and if this is maybe the problem.
Is there something else apart of the LV_USE_VECTOR_GRAPHIC and LV_USE_THORVG_INTERNAL to enable?
I think the issue is that ThorVG is written in C++ and the build system you are using only include plain C files. I am sure this is the case for ESP32 as the esp.cmake file lacks a rule to include them (I opened a pull request Added *.cpp glob in ESP configuration by Maldus512 · Pull Request #5761 · lvgl/lvgl · GitHub), probably it is causing your errors even on Windows or Linux.
