LVGL always returns active screen as currently pressed object
I am trying to use my touch controller as an LVGL input device. LVGL reports the right coordinates when I press the screen, however if I read the currently pressed object (lv_obj_t *act_obj), it has always the same memory address as lv_scr_act() returns regardless the real touched object.
Nordic nRF52832
v8.3
Send custom events to the actual pressed object (label, button, etc.) when touch is detected.
I have tried to modify label size
main.c: create LVGL widgets
void test_cb(lv_event_t *e) {
    lv_label_set_text(lv_event_get_target(e), "Event received");
void create_content() {
    // Create a style
    static lv_style_t style;
    lv_style_init(&style);
    lv_style_set_bg_opa(&style, LV_OPA_COVER);
    lv_style_set_bg_color(&style, lv_color_hex(0x000000));
    lv_obj_add_style(lv_scr_act(), &style, 0);
    // Create a label
    lv_obj_t *time_label = lv_label_create(lv_scr_act());
    lv_label_set_recolor(time_label, true);
    lv_obj_set_align(time_label, LV_ALIGN_CENTER);
    lv_label_set_text(time_label, "Hello world!");
    lv_obj_set_size(time_label, 150, 50);
    // Set event callback
    lv_obj_add_event_cb(time_label, test_cb, LV_EVENT_CUSTOM, NULL);
lvgl_indev_glue.c: associate LVGL with input device driver
static lv_indev_t *indev;
static uint32_t LV_EVENT_CUSTOM;
void lvgl_indev_read(lv_indev_drv_t *indev_drv, lv_indev_data_t *data) {
    // Set the last pressed coordinates
    data -> point.x = get_x();
    data -> point.y = get_y();
    if(touchpad_is_pressed()) {
        data -> state = LV_INDEV_STATE_PR;
    else {
        data -> state = LV_INDEV_STATE_REL;
        if(get_gesture_id() == 0x1c) {
            lv_event_send(indev -> proc.types.pointer.act_obj, LV_EVENT_CUSTOM, NULL); // send an EVENT to the pressed object
            // It reports the right coordinates but pressed object is always the active sceen
            printf("Event sent to object: %p (X: %d, Y: %d)\n", indev -> proc.types.pointer.act_obj, indev -> proc.types.pointer.act_point.x, indev -> proc.types.pointer.act_point.y);
void lvgl_indev_init() {
    printf("Initializing LVGL input device...\n");
    cst816s_init(); // Init touch controller
    indev_drv.read_cb = lvgl_indev_read;
    LV_EVENT_CUSTOM = lv_event_register_id();
    indev = lv_indev_drv_register(&indev_drv);
    if(indev == NULL) {
        printf("Error while registering LVGL input device driver\n");
    else {
        printf("LVGL input device initialized successfully\n");
