LVGL 9 on M5Stack Core2 + PlatformIO example project
I have been playing with LVGL for a bit, and created an example that shows how to get LVGL 9 to run on an M5Stack Core2 (esp32-based) in PlatformIO. It also should work on the M5Stack CoreS3.
The example project is available in this Github repository
I hope this will be helpful for someone.
Finally … Somthing which worked. I’m new to LVGL … This worked like a charm. Now I can use Squareline studio to create UI and use your template to load it in Core 2. Thanks a lot. :slight_smile: , God Bless you ))
