LVGL 9.5.0 Invalidate area is not allowed during rendering Assertion on STM32H7 + FreeRTOS
I am repeatedly hitting the following assertion in LVGL 9.5.0:
LV_ASSERT_MSG(!disp->rendering_in_progress,
              "Invalidate area is not allowed during rendering.");
The assertion occurs from inside my dedicated LVGL thread/task.
Enviroment
  • Version: 9.5.0
  • Color depth: 32-bit
  • Doubled buffered
  • Forked from Riverdies Repository
  • Screen Generated with Squareline Studio
Hardware
  • MCU: STM32H7
  • Resolution: 1024x600
  • Display: Riverdi RVT70HSSNWC00
Software Stack
  • RTOS: FreeRTOS
  • HAL: STM32 HAL
  • Compiler: arm-none-eabi-gcc
  • IDE: STM32CubeIDE
Problem Statement
I have a dedicated LVGL task that periodically calls:
lv_timer_handler();
The same task also updates several labels/widgets using functions like:
DashboardUI_SetSpeed(speed);
DashboardUI_SetRPM(rpm);
DashboardUI_SetBrake(brake);
Eventually the system hits:
From debugging, it appears the invalidation originates from inside the LVGL task itself.
Stack Trace
lv_inv_area() at lv_refr.c:286 0x80183ca
invalidate_area_core() at lv_obj_pos.c:1,448 0x8013ea0
lv_obj_invalidate_area() at lv_obj_pos.c:945 0x8013eec
lv_obj_invalidate() at lv_obj_pos.c:975 0x8013f74
lv_label_mark_need_refr_text() at lv_label.c:1,070 0x8044fd0
lv_label_set_text_vfmt() at lv_label.c:181 0x8045272
lv_label_set_text_fmt() at lv_label.c:153 0x8045294
DashboardUI_SetSpeed() at dashboard_ui.c:22 0x804c8b4
LVGLTimer() at freertos.c:316 0x8001392 0x800ee10
The assertion occurs while lv_label_set_text_fmt() attempts to invalidate the label after updating text.
Current LVGL thread
void LVGLTimer(void *argument)
    TickType_t lastWake = xTaskGetTickCount();
    for (;;)
        uint16_t speed = VehicleState_GetSpeed();
        uint16_t rpm = VehicleState_GetRPM();
        lv_lock();
        lv_unlock();
        lv_lock();
        lv_timer_handler();
        lv_unlock();
        vTaskDelayUntil(&lastWake, pdMS_TO_TICKS(66));
Additional Notes
I’ve also experimented with adding lv_lock()/lv_unlock() calls inside functions such as:
void DashboardUI_SetSpeed(uint16_t speed_kmh)
    lv_lock();
        ui_SpeedBaseTag,
        "%u",
        speed_kmh
    lv_unlock();
However, this did not change the behavior.
Additional Symptoms
Once the assertions occurs, the system becomes unstable and other subsystems appear affected as well. for example:
  • CAN interrupts eventually stop firing
  • The debug UI element still seems to be updating despite the assertion being triggered.
Questions
  1. What should my next debugging steps be?
  2. Is my LVGL thread wrong? I believed I was following the correct structure with having only that thread touch the lv objects
  3. Has anyone else encountered this issue before?
Hi @Mason-Pronger, you enabled the FreeRTOS inside lv_conf.h? You can check this project and try running on PC first. Also it has a main.c for FreeRTOS that can help you understand the FreeRTOS structure.
Regarding the lv_lock and lv_unlock functions, this doc is good way to understand how they work, you are on the right track but there are some minor things.
When this is the case, lv_timer_handler calls lv_lock and lv_unlock internally, so you do not have to bracket your calls to lv_timer_handler with them.
You have to use the mutex calls in others threads.
This is the wrong train of thought. It is not just on a per-thread basis but also just using LVGL functions outside of designated timers or callbacks set up for LVGL.
I recommend moving those dashboardUI_... functions to an LVGL timer instead. Timer (lv_timer) - LVGL 9.5 documentation
You will also need to call lv_tick_inc(...) somewhere. Preferably a hardware timer interrupt (I suppose that is what this LVGLTimer is) you can move lv_timer_handler() to your thread’s main loop instead.
Thank you @bruno and @Tinus for your feedback, I’ve looked into both of your suggestions and believe I’m close to figuring out how to fix my issues.
It seems I had a problem with a separate CAN interrupt that was causing an assert to be triggered. I’ve since addressed that issue and was able to see a corrupted LV image being rendered.
I’ve also read the docs on lv_timer , FreeRTOS integration, and STM32 chip support, and I think I’ve cleaned up my code structure. I added a new lv_timer with its accompanying callback function, and used lv_tick_set_cb(...) to increment the LVGL tick. I believe I now have the correct architecture to work with the LVGL library.
void MX_FREERTOS_Init(void) {
  /* USER CODE BEGIN Init */
	g_can1 = can_port_create(1);
	if (g_can1 != NULL) {
		can_init(g_can1);
		can_start(g_can1);
	g_can2 = can_port_create(2);
	if (g_can2 != NULL) {
		can_init(g_can2);
		can_start(g_can2);
    /* initialize LVGL framework */
    /* initialize display and touchscreen */
    lvgl_display_init();
    lvgl_touchscreen_init();
    lv_tick_set_cb(HAL_GetTick);
    ui_init(); // Squareline generated ui
    /* Create LVGL timer to update dashboard UI */
    lv_timer_create(ui_update_cb, 20, NULL);
  /* USER CODE END Init */
With an accompanying callback function:
 static void ui_update_cb(lv_timer_t *timer)
    uint8_t  brake   = VehicleState_GetBrake();
    uint16_t power   = VehicleState_GetWattage();
    uint8_t  throttle= VehicleState_GetThrottle();
    uint8_t  soc     = VehicleState_GetSOC();
    DashboardUI_SetPower(power);
    DashboardUI_SetThrottle(throttle);
    DashboardUI_SetSOC(soc);
And I’ve cut down the lv_timer_handler() thread to match that in the pc freertos port that Bruno suggested earlier.
    for (;;)
        lv_timer_handler();
        osDelay(5);
I’ll update this thread once I’ve flashed the new version of the firmware on my board and can verify that my issues are resolved.
