LVGL 9.2 with RP2040 and Monochrome Display
Code is hanging after calling “lv_timer_handler_run_in_period”
Raspberry Pi Pico RP2040 with GCC and Visual Studio Code
A working framework that I can then use to get the monochrome display driver (sh1106) working with the LVGL display driver.
Tried following the porting instructions in the docs and the lv_disp_port_template.c
The complete code can be found here “https://github.com/sdwood68/Pico_lvgl”
main code:
/* Includes ----------------------------------------------------------------*/
#include <stdio.h>
#include "pico/stdlib.h"
#include "lvgl/lvgl.h"
#include "pico/binary_info.h"
#include "hardware/i2c.h"
#include "lv_port_disp.h"
 *      DEFINES
#define LED_PIN 		25
// I2C defines
#define I2C_PORT 		i2c0
#define I2C_SDA 		16
#define I2C_SCL 		17
static uint32_t get_millis(void) {
	return to_ms_since_boot(get_absolute_time());
// lv_tick_get_cb_t get_millis_cb = get_millis;
static uint32_t my_tick_get_cb(void) {
	return get_millis();
void toggle_led(uint32_t timeout) {
	static uint32_t last_timeout;
	uint32_t millis = get_millis();
	if (millis - last_timeout > timeout) {
		last_timeout += timeout;
		// printf("[%6d]: ", millis);
		// printf("Hello, world!\n");
		gpio_put(LED_PIN, !gpio_get(LED_PIN));
int main()
    stdio_init_all();
	sleep_ms(5000);
	// uint8_t buffer[sh1106_BUF_SIZE] = { 0xFF };  // all elements 0xFF
	// Default LED
    gpio_init(LED_PIN);
	gpio_set_dir(LED_PIN, GPIO_OUT);
	// I2C Initialisation. Using it at 100Khz.
    i2c_init(I2C_PORT, 400*1000);
    gpio_set_function(I2C_SDA, GPIO_FUNC_I2C);
    gpio_set_function(I2C_SCL, GPIO_FUNC_I2C);
    gpio_pull_up(I2C_SDA);
    gpio_pull_up(I2C_SCL);
	// scanI2C();
	 * LVGL Initialization
	lv_port_disp_init();
	// Tick Initialization
	lv_tick_set_cb(my_tick_get_cb);
	printf("Starting Main loop\n");
	static bool invert = false;
	uint32_t millis = 0;
	uint32_t old_millis = 0;
	while (true) {
		toggle_led(1000);
		lv_timer_handler_run_in_period(10);
lv_port_disp.c
 * @file lv_port_disp_templ.c
/*Copy this file as "lv_port_disp.c" and set this value to "1" to enable content*/
#if 1
 *      INCLUDES
#include "sh1106.h"
#include <stdbool.h>
#include "images/Box.h"
#include "images/circle_16x16x3.h"
 *      DEFINES
#ifndef MY_DISP_HOR_RES
    #define MY_DISP_HOR_RES    128
#ifndef MY_DISP_VER_RES
    #define MY_DISP_VER_RES    64
#define BYTE_PER_PIXEL (LV_COLOR_FORMAT_GET_SIZE(LV_COLOR_FORMAT_I1)) /*will be 2 for RGB565 */
 *      TYPEDEFS
 *  STATIC PROTOTYPES
static void disp_init(void);
static void disp_flush(lv_display_t * disp, const lv_area_t * area, uint8_t * px_map);
 *  STATIC VARIABLES
static sh1106_t sh1106;
 *      MACROS
 *   GLOBAL FUNCTIONS
void lv_port_disp_init(void)
     * Initialize your display
    disp_init();
	printf("Starting LVGL Init\n");
    printf("LVGL Init\n");
     * Create a display and set a flush_cb
    lv_display_t * disp = lv_display_create(MY_DISP_HOR_RES, MY_DISP_VER_RES);
    lv_display_set_flush_cb(disp, disp_flush);
    // Allocate the display buffer
	LV_ATTRIBUTE_MEM_ALIGN
	static uint8_t disp_buf_1[MY_DISP_HOR_RES * MY_DISP_VER_RES * BYTE_PER_PIXEL];
	static uint8_t disp_buf_2[MY_DISP_HOR_RES * MY_DISP_VER_RES * BYTE_PER_PIXEL];
	lv_display_set_buffers(disp, disp_buf_1, disp_buf_2, sizeof(disp_buf_1), LV_DISPLAY_RENDER_MODE_FULL);
 *   STATIC FUNCTIONS
/*Initialize your display and the required peripherals.*/
	printf("Starting sh1106 Display Init\n");
	sh1106_init(&sh1106, I2C_PORT, 0x3C, 128, 64, false, false, false);
	sh1106_flush_buffer(&sh1106, BOX);
 	sh1106_inverted(&sh1106, true);
	// sleep_ms(2000);
	// sh1106_flush_area(&sh1106, 8, 8, 16, 16, CIRCLE_16X16X3);
	// sleep_ms(2000);
	// sh1106_flush_area(&sh1106, 24, 12, 16, 16, CIRCLE_16X16X3);
volatile bool disp_flush_enabled = true;
/* Enable updating the screen (the flushing process) when disp_flush() is called by LVGL */
void disp_enable_update(void)
/* Disable updating the screen (the flushing process) when disp_flush() is called by LVGL */
void disp_disable_update(void)
    disp_flush_enabled = false;
/*Flush the content of the internal buffer the specific area on the display.
 *`px_map` contains the rendered image as raw pixel map and it should be copied to `area` on the display.
 *You can use DMA or any hardware acceleration to do this operation in the background but
 *'lv_display_flush_ready()' has to be called when it's finished.*/
static void disp_flush(lv_display_t * disp_drv, const lv_area_t * area, uint8_t * px_map)
    if(disp_flush_enabled) {
        /*The most simple case (but also the slowest) to put all pixels to the screen one-by-one*/
        // int32_t x;
        // int32_t y;
        // for(y = area->y1; y <= area->y2; y++) {
        //     for(x = area->x1; x <= area->x2; x++) {
        //         /*Put a pixel to the display. For example:*/
        //         /*put_px(x, y, *px_map)*/
        //         px_map++;
        sh1106_flush_buffer(&sh1106, px_map);
    /*IMPORTANT!!!
     *Inform the graphics library that you are ready with the flushing*/
    lv_display_flush_ready(disp_drv);
#else /*Enable this file at the top*/
/*This dummy typedef exists purely to silence -Wpedantic.*/
typedef int keep_pedantic_happy;
By moving lv_tick_set_cb() before lv_init() the main look does not hang at v_timer_handler_run_in_period(); but I’m unable to get the "hello world exable to display anything.
The new main function is below. Code has been updated on github too.
int main()
    stdio_init_all();
	sleep_ms(5000);
	// Default LED
    gpio_init(LED_PIN);
	// Tick Initialization must come first before lv_init()
	lv_tick_set_cb(my_tick);
	lv_obj_t *label = lv_label_create(lv_screen_active());
	lv_label_set_text(label, "Hello World");
	lv_obj_set_style_text_color(lv_screen_active(), lv_color_black(), LV_PART_MAIN);
	while (true) {
		toggle_led(1000);
I’m starting to think that the issue is with the tick interface.
The docs say that lv_init() must come first before any other lv calls, but when I do this lv_timer_handler_run_in_pertod() never returns and I never see a call to disp_flush().
At this point disp_flush() doesn’t do anything. except print a message and then calls lv_display_flush_ready();
Could someone confirm that my assumptions are correct, and does anyone have an example of a raspberry RP2040 tick implementation?
I’ve now got “Hello World” Working on the display. Please refer to Raspberry Pico with Monochrome SH1106 Display Driver for any additional progress.
