LVGL 9.2 Extend current theme error
After update from 9.1 to 9.2 extends current theme example doesn’t work. raise this error
error: aggregate 'lv_theme_t th_new' has incomplete type and cannot be defined
   static lv_theme_t th_new;
ESP32S3 and Platformio
9.2
Works like the 9.1
I try with my code and with example in LVGL doc
LVGL example
#include "../../src/themes/lv_theme_private.h"
#include "../lv_examples.h"
#if LV_BUILD_EXAMPLES && LV_USE_IMAGE
static lv_style_t style_btn;
/*Will be called when the styles of the base theme are already added
  to add new styles*/
static void new_theme_apply_cb(lv_theme_t * th, lv_obj_t * obj)
    LV_UNUSED(th);
    if(lv_obj_check_type(obj, &lv_button_class)) {
        lv_obj_add_style(obj, &style_btn, 0);
static void new_theme_init_and_set(void)
    /*Initialize the styles*/
    lv_style_init(&style_btn);
    lv_style_set_bg_color(&style_btn, lv_palette_main(LV_PALETTE_GREEN));
    lv_style_set_border_color(&style_btn, lv_palette_darken(LV_PALETTE_GREEN, 3));
    lv_style_set_border_width(&style_btn, 3);
    /*Initialize the new theme from the current theme*/
    lv_theme_t * th_act = lv_display_get_theme(NULL);
    th_new = *th_act;
    /*Set the parent theme and the style apply callback for the new theme*/
    lv_theme_set_parent(&th_new, th_act);
    lv_theme_set_apply_cb(&th_new, new_theme_apply_cb);
    /*Assign the new theme to the current display*/
    lv_display_set_theme(NULL, &th_new);
 * Extending the current theme
void lv_example_style_14(void)
    lv_obj_t * btn;
    lv_obj_t * label;
    btn = lv_button_create(lv_screen_active());
    lv_obj_align(btn, LV_ALIGN_TOP_MID, 0, 20);
    label = lv_label_create(btn);
    lv_label_set_text(label, "Original theme");
    new_theme_init_and_set();
    lv_obj_align(btn, LV_ALIGN_BOTTOM_MID, 0, -20);
    lv_label_set_text(label, "New theme");
My code for init and set the theme is this:
  lv_style_init(&styleThemeBkg);
  lv_style_set_bg_color(&styleThemeBkg, lv_color_black());
  lv_style_set_border_color(&styleThemeBkg, lv_color_hex(objectColor));
  lv_style_init(&styleObjectBkg);
  lv_style_set_bg_color(&styleObjectBkg, lv_color_hex(objectColor));
  lv_style_set_border_color(&styleObjectBkg, lv_color_hex(objectColor));
  lv_style_init(&styleObjectSel);
  lv_style_set_bg_color(&styleObjectSel, lv_color_hex(0x757575));
  lv_theme_t *th_act = lv_disp_get_theme(NULL);
  th_new = *th_act;
  lv_theme_set_apply_cb(&th_new, applyModifyTheme);
  lv_disp_set_theme(NULL, &th_new);
Solved adding
#include "lvgl_private.h"
