ESP32 Wroom + Screen ILI9225 + Arduino IDE
9.1.0
Rotate my screen in portrait
lv_display_set_rotation(disp,LV_DISPLAY_ROTATION_270);
INO file (draw a button and a text):
#include <lvgl.h>
#if LV_USE_TFT_ESPI
#include <TFT_eSPI.h>
#define TFT_HOR_RES 220
#define TFT_VER_RES 176
#define DRAW_BUF_SIZE (TFT_HOR_RES * TFT_VER_RES / 10 * (LV_COLOR_DEPTH / 8))
uint32_t draw_buf[DRAW_BUF_SIZE / 4];
lv_obj_t *label_time;
uint8_t xxx = 0;
void setup()
Serial.begin(115200);
lv_tick_set_cb(millis);
lv_display_t *disp;
disp = lv_tft_espi_create(TFT_HOR_RES, TFT_VER_RES, draw_buf, sizeof(draw_buf));
lv_obj_t * btn = lv_button_create(lv_screen_active()); /*Add a button the current screen*/
lv_obj_set_pos(btn, 10, 10); /*Set its position*/
lv_obj_set_size(btn, 120, 50); /*Set its size*/
static lv_style_t style;
lv_style_init(&style);
lv_style_set_text_color(&style, lv_color_black());
label_time = lv_label_create(lv_scr_act());
lv_obj_add_style(label_time, &style, 0);
lv_obj_align(label_time, LV_ALIGN_BOTTOM_MID, 0, -20);
void loop()
lv_task_handler();
if(xxx==0){
xxx=1;
unsigned long elapsedMillis = millis();
String timeText = "Millisecondes ecoulees: " + String(elapsedMillis);
lv_label_set_text(label_time, timeText.c_str());
Serial.println(timeText.c_str());
→ the 4 rotations (0, 90, 180, 270) have the same orientation, landscape, 90° more than what I want
–>0 and 180°: the objects are dispatched correctly (excepted the orientation)
–>90 and 270: the objects are cut (I guess it cuts the width of the screen to the heith value)
Note: they were drawn under squareline in portrait but display in landscape
Note: I am experienced in C and C++ but new to LVGL. I read blogs from 2022 with similar issue but I don’t know if it is partially corrected (needing an adaptation for my screen) or still unsolved (meaning that I must go down to LVGL 8). Thanks!
Rotation 0 or 180:
Rotation 90:
Rotation 270:
