The framebuffer device was opened successfully.
800x480, 16bpp
The framebuffer device was mapped to memory successfully.
[Info] (0.011, +11) lv_obj_create: begin (in lv_obj.c line #188)
[Info] (0.011, +0) lv_obj_create: begin (in lv_obj.c line #188)
Indev Keypad = 0xdd5d98
the Indev keypad = 0xdd5d98
[Info] (0.017, +6) lv_obj_create: begin (in lv_obj.c line #188)
[Info] (0.020, +3) lv_label_create: begin (in lv_label.c line #75)
[Info] (0.023, +3) lv_obj_create: begin (in lv_obj.c line #188)
[Info] (0.024, +1) lv_label_create: begin (in lv_label.c line #75)
[Info] (0.025, +1) lv_img_create: begin (in lv_img.c line #59)
[Info] (0.026, +1) lv_img_create: begin (in lv_img.c line #59)
[Info] (0.027, +1) lv_img_create: begin (in lv_img.c line #59)
[Info] (0.028, +1) lv_img_create: begin (in lv_img.c line #59)
[Info] (0.029, +1) lv_list_create: begin (in lv_list.c line #58)
[Info] (0.030, +1) lv_list_add_btn: begin (in lv_list.c line #78)
[Info] (0.030, +0) lv_img_create: begin (in lv_img.c line #59)
[Info] (0.032, +2) lv_label_create: begin (in lv_label.c line #75)
[Info] (0.032, +0) lv_list_add_btn: begin (in lv_list.c line #78)
[Info] (0.032, +0) lv_img_create: begin (in lv_img.c line #59)
[Info] (0.033, +1) lv_label_create: begin (in lv_label.c line #75)
[Info] (0.033, +0) lv_list_add_btn: begin (in lv_list.c line #78)
[Info] (0.036, +3) lv_img_create: begin (in lv_img.c line #59)
[Info] (0.036, +0) lv_label_create: begin (in lv_label.c line #75)
[Info] (0.037, +1) lv_list_add_btn: begin (in lv_list.c line #78)
[Info] (0.038, +1) lv_img_create: begin (in lv_img.c line #59)
[Info] (0.038, +0) lv_label_create: begin (in lv_label.c line #75)
[Info] (0.039, +1) lv_list_add_btn: begin (in lv_list.c line #78)
[Info] (0.040, +1) lv_img_create: begin (in lv_img.c line #59)
[Info] (0.044, +4) lv_label_create: begin (in lv_label.c line #75)
[Info] (0.045, +1) lv_list_add_btn: begin (in lv_list.c line #78)
[Info] (0.045, +0) lv_img_create: begin (in lv_img.c line #59)
[Info] (0.046, +1) lv_label_create: begin (in lv_label.c line #75)
[Info] (0.047, +1) lv_list_add_btn: begin (in lv_list.c line #78)
[Info] (0.048, +1) lv_img_create: begin (in lv_img.c line #59)
[Info] (0.049, +1) lv_label_create: begin (in lv_label.c line #75)
[Info] (0.050, +1) lv_list_add_btn: begin (in lv_list.c line #78)
[Info] (0.051, +1) lv_img_create: begin (in lv_img.c line #59)
[Info] (0.051, +0) lv_label_create: begin (in lv_label.c line #75)
[Info] (0.055, +4) lv_list_add_btn: begin (in lv_list.c line #78)
[Info] (0.056, +1) lv_img_create: begin (in lv_img.c line #59)
[Info] (0.057, +1) lv_label_create: begin (in lv_label.c line #75)
[Info]of(0.059, +2)= 0 lv_obj_update_layout: Layout update begin (in lv_obj_pos.c line #302)
[Info] (0.060, +1) flex_update: update 0xdd6388 container (in lv_flex.c line #207)
[Info] (0.064, +4) flex_update: update 0xdd63c0 container (in lv_flex.c line #207)
[Info] (0.066, +2) flex_update: update 0xdd67ac container (in lv_flex.c line #207)
[Info] (0.067, +1) flex_update: update 0xdd67d4 container (in lv_flex.c line #207)
[Info] (0.068, +1) flex_update: update 0xdd6bc0 container (in lv_flex.c line #207)
[Info] (0.070, +2) flex_update: update 0xdd6dd0 container (in lv_flex.c line #207)
[Info] (0.072, +2) flex_update: update 0xdd6fe4 container (in lv_flex.c line #207)
[Info] (0.075, +3) flex_update: update 0xdd71f8 container (in lv_flex.c line #207)
[Info] (0.076, +1) flex_update: update 0xdd7404 container (in lv_flex.c line #207)
[Info] (0.077, +1) flex_update: update 0xdd62dc container (in lv_flex.c line #207)
[Info] (0.078, +1) lv_obj_update_layout: Layout update begin (in lv_obj_pos.c line #302)
[Info] (0.079, +1) flex_update: update 0xdd6388 container (in lv_flex.c line #207)
[Info] (0.085, +6) flex_update: update 0xdd63c0 container (in lv_flex.c line #207)
[Info] (0.085, +0) flex_update: update 0xdd67ac container (in lv_flex.c line #207)
[Info] (0.086, +1) flex_update: update 0xdd67d4 container (in lv_flex.c line #207)
[Info] (0.087, +1) flex_update: update 0xdd6bc0 container (in lv_flex.c line #207)
[Info] (0.088, +1) flex_update: update 0xdd6dd0 container (in lv_flex.c line #207)
[Info] (0.089, +1) flex_update: update 0xdd6fe4 container (in lv_flex.c line #207)
[Info] (0.089, +0) flex_update: update 0xdd71f8 container (in lv_flex.c line #207)
[Info] (0.090, +1) flex_update: update 0xdd7404 container (in lv_flex.c line #207)
[Info] (0.091, +1) flex_update: update 0xdd62dc container (in lv_flex.c line #207)
[Info] (0.092, +1) lv_obj_update_layout: Layout update begin (in lv_obj_pos.c line #302)
[Info] (0.093, +1) flex_update: update 0xdd6388 container (in lv_flex.c line #207)
[Info] (0.093, +0) flex_update: update 0xdd63c0 container (in lv_flex.c line #207)
[Info] (0.095, +2) flex_update: update 0xdd67ac container (in lv_flex.c line #207)
[Info] (0.096, +1) flex_update: update 0xdd67d4 container (in lv_flex.c line #207)
[Info] (0.096, +0) flex_update: update 0xdd6bc0 container (in lv_flex.c line #207)
[Info] (0.097, +1) flex_update: update 0xdd6dd0 container (in lv_flex.c line #207)
[Info] (0.097, +0) flex_update: update 0xdd6fe4 container (in lv_flex.c line #207)
[Info] (0.101, +4) flex_update: update 0xdd71f8 container (in lv_flex.c line #207)
[Info] (0.101, +0) flex_update: update 0xdd7404 container (in lv_flex.c line #207)
[Info] (0.102, +1) lv_obj_update_layout: Layout update begin (in lv_obj_pos.c line #302)
[Info] (0.102, +0) lv_obj_update_layout: Layout update begin (in lv_obj_pos.c line #302)
[Info] (0.125, +23) lv_label_create: begin (in lv_label.c line #75)
[Info] (0.129, +4) lv_label_create: begin (in lv_label.c line #75)
[Info]of(0.172, +43) 0 lv_obj_update_layout: Layout update begin (in lv_obj_pos.c line #302)
[Info] (0.172, +0) lv_obj_update_layout: Layout update begin (in lv_obj_pos.c line #302)
[Info]of(0.377, +205)0 lv_obj_update_layout: Layout update begin (in lv_obj_pos.c line #302)
[Info] (0.377, +0) lv_obj_update_layout: Layout update begin (in lv_obj_pos.c line #302)
Hit Down data->key = 0
[Info]of(0.584, +207)18 indev_keypad_proc: 18 key is pressed (in lv_indev.c line #406)
Hit Down
Hit Down data->key = 18
[Info]of(0.707, +123)18 lv_obj_update_layout: Layout update begin (in lv_obj_pos.c line #302)
[Info] (0.708, +1) lv_obj_update_layout: Layout update begin (in lv_obj_pos.c line #302)
Hit Down
[Info]of(1.042, +334)18 indev_keypad_proc: 18 key is released (in lv_indev.c line #490)
[Info] (1.042, +0) lv_obj_update_layout: Layout update begin (in lv_obj_pos.c line #302)
[Info]of(1.371, +329)18 lv_obj_update_layout: Layout update begin (in lv_obj_pos.c line #302)
[Info] (1.371, +0) lv_obj_update_layout: Layout update begin (in lv_obj_pos.c line #302)
Hit Enter ata->key = 18
[Info]of(1.460, +89) 10 indev_keypad_proc: 10 key is pressed (in lv_indev.c line #406)
Hit Enter
Hit Enter ata->key = 10
[Info]of(1.708, +248)10 lv_obj_update_layout: Layout update begin (in lv_obj_pos.c line #302)
Hit Enter
[Info]of(1.997, +289)10 indev_keypad_proc: 10 key is released (in lv_indev.c line #490)
[Info]of(2.038, +41) 10 lv_obj_update_layout: Layout update begin (in lv_obj_pos.c line #302)
[Info]of(2.368, +330)10 lv_obj_update_layout: Layout update begin (in lv_obj_pos.c line #302)
[Info]of(2.698, +330)10 lv_obj_update_layout: Layout update begin (in lv_obj_pos.c line #302)
Hit Up f data->key = 10
[Info]of(2.784, +86) 17 indev_keypad_proc: 17 key is pressed (in lv_indev.c line #406)
Hit Up
Hit Up f data->key = 17
[Info]of(3.030, +246)17 lv_obj_update_layout: Layout update begin (in lv_obj_pos.c line #302)
Hit Up
[Info]of(3.201, +171)17 indev_keypad_proc: 17 key is released (in lv_indev.c line #490)
[Info]of(3.365, +164)17 lv_obj_update_layout: Layout update begin (in lv_obj_pos.c line #302)
[Info] (3.365, +0) lv_obj_update_layout: Layout update begin (in lv_obj_pos.c line #302)
[Info]of(3.695, +330)17 lv_obj_update_layout: Layout update begin (in lv_obj_pos.c line #302)
[Info]of(4.031, +336)17 lv_obj_update_layout: Layout update begin (in lv_obj_pos.c line #302)
[Info] (4.038, +7) lv_obj_update_layout: Layout update begin (in lv_obj_pos.c line #302)
[Info]of(4.329, +291)17 lv_obj_update_layout: Layout update begin (in lv_obj_pos.c line #302)
[Info] (4.329, +0) lv_obj_update_layout: Layout update begin (in lv_obj_pos.c line #302)
Hit Down data->key = 17
[Info]of(4.621, +292)18 indev_keypad_proc: 18 key is pressed (in lv_indev.c line #406)
Hit Down
[Info]of(4.662, +41) 18 lv_obj_update_layout: Layout update begin (in lv_obj_pos.c line #302)
Hit Down
[Info]of(4.747, +85) 18 indev_keypad_proc: 18 key is released (in lv_indev.c line #490)
[Info]of(4.993, +246)18 lv_obj_update_layout: Layout update begin (in lv_obj_pos.c line #302)
[Info] (4.993, +0) lv_obj_update_layout: Layout update begin (in lv_obj_pos.c line #302)
Hit TAB data->key = 18
[Info]of(5.199, +206)9 indev_keypad_proc: 9 key is pressed (in lv_indev.c line #406)
Hit TAB
Hit TAB data->key = 9
[Info]of(5.322, +123)9 lv_obj_update_layout: Layout update begin (in lv_obj_pos.c line #302)
Hit TAB
[Info]of(5.452, +130)9 indev_keypad_proc: 9 key is released (in lv_indev.c line #490)
[Info]of(5.656, +204)9 lv_obj_update_layout: Layout update begin (in lv_obj_pos.c line #302)
[Info]of(5.984, +328)9 lv_obj_update_layout: Layout update begin (in lv_obj_pos.c line #302)
[Info]of(6.313, +329)9 lv_obj_update_layout: Layout update begin (in lv_obj_pos.c line #302)
the printfs are ok i can see the value of
LV_KEY_ENTER
LV_KEY_UP
LV_KEY_NEXT
LV_KEY_DOWN
but i think in the 8 version of lvgl I should set a flag in the lv_conf file or something like this to using keypad group!?.
