LVGL 8.3 + IL9341 + XPT2046 touch not working
esp32s3
8.3
tft screen working but touch not working
tft+touch same bus
what is wrong ?
#define LGFX_USE_V1
#include <LovyanGFX.hpp>
#include <driver/i2c.h>
// Portrait
#define TFT_WIDTH   240
#define TFT_HEIGHT  320
#define SPI_HOST_ID SPI2_HOST
#define TFT_MOSI    GPIO_NUM_14
#define TFT_MISO    GPIO_NUM_19  // Set this PIN for using shared SPI option
#define TFT_SCLK    GPIO_NUM_18
#define TFT_DC      GPIO_NUM_21
#define TFT_CS      GPIO_NUM_15
#define TFT_RST     GPIO_NUM_17
#define TFT_BL      -1
#define TFT_RTOUCH_CS	GPIO_NUM_46
#define TFT_RIQ	GPIO_NUM_47
class LGFX : public lgfx::LGFX_Device
    // provide an instance that matches the type of panel you want to connect to.
    lgfx::Panel_ILI9341 _panel_instance;
    // provide an instance that matches the type of bus to which the panel is connected.
    lgfx::Bus_SPI _bus_instance; // Instances of spi buses
    //Prepare an instance that matches the type of touchscreen.
  //  lgfx::Touch_FT5x06  _touch_instance;
		lgfx::Touch_XPT2046 _touch_instance;
	//lgfx::Touch_STMPE610 _touch_instance;
    //lgfx::Light_PWM     _light_instance;
public:
  LGFX(void)
      // set up bus control.
      auto cfg = _bus_instance.config(); // gets the structure for bus settings.
      // SPI bus settings
      cfg.spi_host = SPI_HOST_ID;// SPI_HOST_ID; // Select SPI to use ESP32-S2,C3: SPI2_HOST or SPI3_HOST / ESP32: VSPI_HOST or HSPI_HOST
      //* Due to the ESP-IDF upgrade, the description of VSPI_HOST , HSPI_HOST will be deprecated, so if you get an error, use SPI2_HOST , SPI3_HOST instead.
      cfg.spi_mode = 0;          // Set SPI communication mode (0-3)
      cfg.freq_write = 40000000; // SPI clock on transmission (up to 80MHz, rounded to 80MHz divided by integer)
      cfg.freq_read = 16000000;  // SPI clock on reception
      cfg.spi_3wire = true;      // Set true when receiving on the MOSI pin
      cfg.use_lock = true;       // set true if transaction lock is used
      //  * With the ESP-IDF version upgrade, SPI_DMA_CH_AUTO (automatic setting) of DMA channels is recommended.
      cfg.dma_channel = SPI_DMA_CH_AUTO; // Set DMA channel to be used (0=DMA not used / 1=1ch / 2=ch / SPI_DMA_CH_AUTO=Auto setting)
      cfg.pin_sclk = TFT_SCLK; // Set SCLK pin number for SPI
      cfg.pin_mosi = TFT_MOSI; // Set SPI MOSI pin number
      // When using the SPI bus, which is common to the SD card, be sure to set MISO without omitting it.
      cfg.pin_miso = TFT_MISO; // Set THE MSO pin number of spi (-1 = disable)
      cfg.pin_dc = TFT_DC;    // Set THE D/C pin number of SPI (-1 = disable)
      _bus_instance.config(cfg);              // reflects the setting value on the bus.
      _panel_instance.setBus(&_bus_instance); // Set the bus to the panel.
      // set the display panel control.
      auto cfg = _panel_instance.config(); // gets the structure for display panel settings.
      cfg.pin_cs = TFT_CS;    // Pin number to which CS is connected (-1 = disable)
      cfg.pin_rst = TFT_RST;  // Pin number to which RST is connected (-1 = disable)
      cfg.pin_busy = -1;      // Pin number to which BUSY is connected (-1 = disable)
      // the following setting values are set to a general initial value for each panel,
      cfg.panel_width = TFT_WIDTH;    // actual visible width
      cfg.panel_height = TFT_HEIGHT;   // actually visible height
      cfg.offset_x = 0;         // Panel X-direction offset amount
      cfg.offset_y = 0;         // Panel Y offset amount
      cfg.offset_rotation = 0;  // offset of rotational values from 0 to 7 (4 to 7 upside down)
      cfg.dummy_read_pixel = 8; // number of bits in dummy leads before pixel read
      cfg.dummy_read_bits = 1;  // number of bits in dummy leads before reading non-pixel data
      cfg.readable = true;      // set to true if data can be read
      cfg.invert = false;       // set to true if the light and dark of the panel is reversed
      cfg.rgb_order = false;    // set to true if the red and blue of the panel are swapped
      cfg.dlen_16bit = false;   // Set to true for panels that transmit data lengths in 16-bit increments in 16-bit parallel or SPI
      cfg.bus_shared = true;    // Set to true when sharing the bus with sd card (bus control is performed with drawJpgFile, etc.)
      // The following should only be set if the display is misalized by a driver with a variable number of pixels, such as st7735 or ILI9163.
      // cfg.memory_width = 240; //Maximum width supported by driver ICs
      // cfg.memory_height = 320; //Maximum height supported by driver ICs
      _panel_instance.config(cfg);
        auto cfg = _touch_instance.config();
        cfg.x_min = 0;  //Smallest X value (raw value) obtained from the touch screen
        cfg.x_max = 239;  //The maximum X value (raw value) obtained from the touch screen
        cfg.y_min = 0;  //Smallest Y value (raw value) obtained from the touch screen
        cfg.y_max = 319;  //The largest Y-value (raw value) obtained from the touchscreen
        cfg.pin_int = TFT_RIQ;//38;  //Number of pins to which INT is connected
        cfg.bus_shared = true;  //Set to true if using a bus that is common to the screen
        cfg.offset_rotation = 0;  //Adjustment when the display and touch orientations do not match Set with a value of 0~7
        // For SPI connections
        cfg.spi_host = SPI_HOST_ID;  //Select SPI to use (HSPI_HOST or VSPI_HOST)
        cfg.freq = 1*1000*1000;  //Set the SPI Clock
        cfg.pin_sclk = TFT_SCLK;  //Pin number to which SCLK is connected
        cfg.pin_mosi = TFT_MOSI;  //Number of pins to which MOSI is connected
        cfg.pin_miso = TFT_MISO;  //Pin number to which MISO is connected
        cfg.pin_cs = TFT_RTOUCH_CS;  //Pin number to which CS is connected
        _touch_instance.config(cfg);
        _panel_instance.setTouch(&_touch_instance);  //Set the touch screen on the panel.
    setPanel(&_panel_instance); // Set the panel to be used.
can anyone help me ?
I haven’t used arduino libraries, but have you tried example code? Have you found any examples that use the same set up and tried them?
