/* LVGL Example project
- Basic project to test LVGL on ESP32 based projects.
- This example code is in the Public Domain (or CC0 licensed, at your option.)
- Unless require1d by applicable law or agreed to in writing, this
- software is distributed on an “AS IS” BASIS, WITHOUT WARRANTIES OR
- CONDITIONS OF ANY KIND, either express or implied.
#include “esp_system.h”
#include “esp_timer.h”
#include “freertos/FreeRTOS.h”
#include “freertos/semphr.h”
#include “freertos/task.h”
#include <esp_log.h>
#include <stdbool.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
/* Littlevgl specific */
#ifdef LV_LVGL_H_INCLUDE_SIMPLE
#include “lvgl.h”
#else
#include “lvgl/lvgl.h”
#include “lvgl_helpers.h”
#ifndef CONFIG_LV_TFT_DISPLAY_MONOCHROME
#if defined CONFIG_LV_USE_DEMO_WIDGETS
#include “lv_examples/src/lv_demo_widgets/lv_demo_widgets.h”
#elif defined CONFIG_LV_USE_DEMO_KEYPAD_AND_ENCODER
#include “lv_examples/src/lv_demo_keypad_encoder/lv_demo_keypad_encoder.h”
#elif defined CONFIG_LV_USE_DEMO_BENCHMARK
#include “lv_examples/src/lv_demo_benchmark/lv_demo_benchmark.h”
#elif defined CONFIG_LV_USE_DEMO_STRESS
#include “lv_examples/src/lv_demo_stress/lv_demo_stress.h”
#else
#ifndef MY_DISP_HOR_RES
#define MY_DISP_HOR_RES 128
#ifndef MY_DISP_VER_RES
#define MY_DISP_VER_RES 64
DEFINES
#define TAG “demo”
#define LV_TICK_PERIOD_MS 10
- STATIC PROTOTYPES
static void lv_tick_task(void *arg);
static void guiTask(void *pvParameter);
static void create_demo_application(void);
- APPLICATION MAIN
void app_main() {
/* If you want to use a task to create the graphic, you NEED to create a
- Pinned task Otherwise there can be problem such as memory corruption and so
- on. NOTE: When not using Wi-Fi nor Bluetooth you can pin the guiTask to
- core 0 */
xTaskCreatePinnedToCore(guiTask, “gui”, 4096 * 2, NULL, 0, NULL, 1);
/* Creates a semaphore to handle concurrent call to lvgl stuff
- If you wish to call any lvgl function from other threads/tasks
- you should lock on the very same semaphore! */
SemaphoreHandle_t xGuiSemaphore;
static void guiTask(void *pvParameter) {
(void)pvParameter;
xGuiSemaphore = xSemaphoreCreateMutex();
/* Initialize SPI or I2C bus used by the drivers */
lvgl_driver_init();
lv_color_t *buf1 =
heap_caps_malloc(DISP_BUF_SIZE * sizeof(lv_color_t), MALLOC_CAP_DMA);
assert(buf1 != NULL);
/* Use double buffered when not working with monochrome displays */
lv_color_t *buf2 =
assert(buf2 != NULL);
#else
static lv_color_t *buf2 = NULL;
// static lv_color_t buf_1[MY_DISP_HOR_RES * 10];
uint32_t size_in_px = DISP_BUF_SIZE;
#if defined CONFIG_LV_TFT_DISPLAY_CONTROLLER_IL3820 ||
defined CONFIG_LV_TFT_DISPLAY_CONTROLLER_JD79653A ||
defined CONFIG_LV_TFT_DISPLAY_CONTROLLER_UC8151D ||
defined CONFIG_LV_TFT_DISPLAY_CONTROLLER_SSD1306
/* Actual size in pixels, not bytes. */
size_in_px *= 8;
/* Initialize the working buffer depending on the selected display.
- NOTE: buf2 == NULL when using monochrome displays. */
lv_disp_draw_buf_init(&disp_buf, buf1, buf2,
MY_DISP_HOR_RES * MY_DISP_VER_RES);
lv_disp_drv_init(&disp_drv);
disp_drv.hor_res = MY_DISP_HOR_RES;
disp_drv.ver_res = MY_DISP_VER_RES;
disp_drv.flush_cb = disp_driver_flush;
#if defined CONFIG_DISPLAY_ORIENTATION_PORTRAIT ||
defined CONFIG_DISPLAY_ORIENTATION_PORTRAIT_INVERTED
disp_drv.rotated = 1;
TY
/* When using a monochrome display we need to register the callbacks:
- rounder_cb
- set_px_cb */
#ifdef CONFIG_LV_TFT_DISPLAY_MONOCHROME
disp_drv.rounder_cb = disp_driver_rounder;
disp_drv.set_px_cb = disp_driver_set_px;
- set_px_cb */
/* Register an input device when enabled on the menuconfig */
#if CONFIG_LV_TOUCH_CONTROLLER != TOUCH_CONTROLLER_NONE
lv_indev_drv_t indev_drv;
indev_drv.read_cb = touch_driver_read;
/* Create and start a periodic timer interrupt to call lv_tick_inc */
const esp_timer_create_args_t periodic_timer_args = {
.callback = &lv_tick_task, .name = “periodic_gui”};
esp_timer_handle_t periodic_timer;
ESP_ERROR_CHECK(esp_timer_create(&periodic_timer_args, &periodic_timer));
ESP_ERROR_CHECK(
esp_timer_start_periodic(periodic_timer, LV_TICK_PERIOD_MS * 1000));
/* Create the demo application */
create_demo_application();
while (1) {
/* Delay 1 tick (assumes FreeRTOS tick is 10ms */
/* Try to take the semaphore, call lvgl related function on success */
if (pdTRUE == xSemaphoreTake(xGuiSemaphore, portMAX_DELAY)) {
lv_task_handler();
xSemaphoreGive(xGuiSemaphore);
/* A task should NEVER return */
free(buf1);
free(buf2);
vTaskDelete(NULL);
static void create_demo_application(void) {
/* When using a monochrome display we only show “Hello World” centered on the
- screen */
#if defined CONFIG_LV_TFT_DISPLAY_MONOCHROME ||
defined CONFIG_LV_TFT_DISPLAY_CONTROLLER_ST7735S
/* use a pretty small demo for monochrome displays /
/ Get the current screen */
// lv_obj_t *scr = lv_disp_get_scr_act(NULL);
/Create a Label on the currently active screen/
lv_obj_t *label1 = lv_label_create(lv_scr_act());
// lv_obj_t *label1 = lv_label_create(lv_scr_act());
/Modify the Label’s text/
lv_label_set_text(label1, “Hello\nworld”);
/* Align the Label to the center
- NULL means align on parent (which is the screen now)
- 0, 0 at the end means an x, y offset after alignment*/
lv_obj_set_width(label1, 10);
lv_obj_align_to(label1, NULL, LV_ALIGN_CENTER, 0, 0);
ESP_LOGI(TAG, “SSD1306 call Hello world”);
#else
/* Otherwise we show the selected demo */
lv_demo_widgets();
lv_demo_widgets();
lv_demo_keypad_encoder();
lv_demo_benchmark();
lv_demo_stress();
#else
static void lv_tick_task(void *arg) {
(void)arg;
lv_tick_inc(LV_TICK_PERIOD_MS);
/* For the monochrome display driver controller, e.g. SSD1306 and SH1107, use a color depth of 1. */
#define LV_THEME_DEFAULT_COLOR_PRIMARY LV_COLOR_BLACK
#define LV_THEME_DEFAULT_COLOR_SECONDARY LV_COLOR_WHITE
#define LV_COLOR_DEPTH 1
#else
#define LV_COLOR_DEPTH 16
