I’m trying to get a “Label example” to run on the stm32f746G-Discovery board.
I’m getting a HardFault somewhere inside lv_timer_handler().
I was using the master branch of LVGL and master branch of the stm32f746-port aswell. Not sure if I should use a specific version of them both?
So far I’m not using external SDRAM, so I did some modifications to the LVGL code, for example change my_fb[] to use the one stored in internal RAM, and changed LV_MEM_SIZE to a smaller size.
What can be the issue with lv_timer_handler()?
I should also mention that I call lv_tick_inc(1) in SysTick_Handler()
STM32F746G-Discovery
Get example code to run on the device.
Followed a course (https://www.udemy.com/course/mastering-microcontroller-stm32-ltdc-lcd-tft-lvgl/) on Udemy to get some teoretical background on LCD/Graphics programming.
I’m using VSCode and CMake based build system, and generating the HAL layer from STMCubeMX. Both I2C3 and LCD peripherals are enabled.
/*int main(void)
stm32f7_cubemx_init();
system_init();
tft_init();
touchpad_init();
lv_example_label_1();
while (1)
my_printf("--hello from stm32f7--");
HAL_Delay(50);
lv_timer_handler();
my_printf("lv_timer_handler");
