How to add a second state (adding an extra style conditionally based on a state) for a lv_tabview
tab button.
v8.2.0
I’m using lv_tabview
object on LvGL v8.2. I have made a custom style for the LV_STATE_CHECKED
state, to add a blue line under the button. This work well.
I need a second style, which should be applied on a specific tab. What I have in mind is to add another colored line on the top border of a button.
To add a line on the bottom border of the button, the code is the following :
style_init_reset(&styles->tab_btn);
lv_style_set_border_color(&styles->tab_btn, CY_BLUE);
lv_style_set_border_width(&styles->tab_btn, 4);
lv_style_set_border_side(&styles->tab_btn, LV_BORDER_SIDE_BOTTOM);
#if LV_USE_TABVIEW
if(lv_obj_check_type(lv_obj_get_parent(obj), &lv_tabview_class)) {
lv_obj_add_style(obj, &styles->tab_btn, LV_PART_ITEMS | LV_STATE_CHECKED);
return;
For the second state, I tried to use the LV_STATE_USER_1
state, but without success. I didn’t find any example using this state.
Basically, what I did is :
style_init_reset(&styles->tab_focus);
lv_style_set_border_color(&styles->tab_focus, CY_YELLOW);
lv_style_set_border_width(&styles->tab_focus, 4);
lv_style_set_border_side(&styles->tab_focus, LV_BORDER_SIDE_TOP);
#if LV_USE_TABVIEW
lv_obj_add_style(obj, &styles->tab_focus, LV_PART_ITEMS | LV_STATE_USER_1);
return;
and to use this new state :
void tabscreen_set_focus(int idx, int state)
if (state)
lv_obj_add_state(tab[idx], LV_STATE_USER_1);
lv_obj_clear_state(tab[idx], LV_STATE_CHECKED);
tab[i]
is a lv_obj_t
returned by the function lv_tabview_add_tab(...)
I don’t really understand why this doesn’t work. I’m not sure to apply the state to the correct object, or if it is the style that is not on the correct object class. Does anybody have an idea or tips to do what I want to do?
Help would be appreciated
