LV_STYLE_CONST_BG_COLOR does not set colors properly
When setting a lv_style_const_prop_t value involving colors (border color, bg_color, outline_color, shadow_color, etc) the entered color value is converted from a 32-bit integer to an 8-bit integer. This means you can only modify the blue color channel, and you cannot modify green or red channels.
This can be corrected by changing the .value field in lv_style_gen.h from .color to .num:
#define LV_STYLE_CONST_BG_COLOR(val)
.prop = LV_STYLE_BG_OPA, .value = { .color .num = Val }
Desktop Linux, x86, GCC
V9.2.2
Properly set const color style
Modifying lv_style_gen.h can fix the issue
const lv_style_const_prop_t style_props = {
LV_STYLE_CONST_BG_COLOR(0xFFFFFF), //should be white, is blue due to error
LV_STYLE_CONST_PROPS_END
LV_STYLE_CONST_INIT(myStyle, &style_props);
Oh, it really wasn’t intuitive.
I could make it work correctly like this:
    const lv_style_const_prop_t style1_props[] = {
       LV_STYLE_CONST_WIDTH(50),
       LV_STYLE_CONST_HEIGHT(50),
	   LV_STYLE_CONST_BG_COLOR((lv_color_t)LV_COLOR_MAKE(0xFF, 0x00, 0xFF)),
