I have implemented a simple roller for setting minutes, so the data is 0-59.
When the roller is set to infinite and there more than 36 elements the selected area is rendered incorrectly, the numbers are out of sync and not centralised, I noticed the bug because it wasn’t apparent on the hour setting.
I have attached some screenshots, I have noticed some updates to the roller class on the latest project, but the changes are extensive to whole lvgl library which I am not in a position to update.
I have tried to delve in look at anything obvious, but the code isn’t straight forward.
As I say this only happens when the number of elements are greater than 36
Thank you in advance
