Lv_obj_set_user_data
Hi @kisvegabor and @embeddedt
i am facing a small issue with “lv_obj_set_user_data”
i have created custom list using area.
when i click on each area i want to print particular data regarding that area.
the data passing to “lv_obj_set_user_data” is printing correctly when 1st click but on 2nd click data not printing.
for every area created with forloop printing correct data for first click. on 2nd click printing only small value.
i am attaching my sample code below.
i need your support to solve this issue.
Please help me with this issue. i don’t know where i did mistake.
Thanks in advance.
ARM
v7
void room_devices(char *arr_device_name[],char *arr_device_id[],char *arr_device_type[],char *arr_device_client[])
    static lv_style_t lv_style_title;
    lv_style_init(&lv_style_title);
    lv_style_set_text_font(&lv_style_title, LV_STATE_DEFAULT, &lv_font_montserrat_24);
    lv_style_set_text_color(&lv_style_title, LV_STATE_DEFAULT, LV_COLOR_WHITE);
    static lv_style_t lv_style_text;
    lv_style_init(&lv_style_text);
    lv_style_set_text_font(&lv_style_text, LV_STATE_DEFAULT, &lv_font_montserrat_30);
    lv_style_set_text_color(&lv_style_text, LV_STATE_DEFAULT, LV_COLOR_GRAY);
    /*Line style*/
    static lv_style_t style_line;
    lv_style_init(&style_line);
    lv_style_set_line_width(&style_line, LV_STATE_DEFAULT, 2);
    lv_style_set_line_color(&style_line, LV_STATE_DEFAULT, LV_COLOR_GRAY);
    lv_style_set_line_rounded(&style_line, LV_STATE_DEFAULT, true);
    //page style
    static lv_style_t style_page;
    lv_style_init(&style_page);
    lv_style_set_bg_color(&style_page,LV_STATE_DEFAULT, LV_COLOR_BLACK);
    lv_style_set_border_width(&style_page,LV_STATE_DEFAULT,0);
    lv_style_set_text_color(&style_page,LV_STATE_DEFAULT,LV_COLOR_WHITE);
    lv_style_set_text_font(&style_page, LV_STATE_DEFAULT, &lv_font_montserrat_24);
    lv_style_set_line_width(&style_page,LV_STATE_DEFAULT,30);
    //style_box
    static lv_style_t style_box;
    lv_style_init(&style_box);
    lv_style_set_bg_color(&style_box,LV_STATE_DEFAULT,LV_COLOR_BLACK);
    lv_style_set_pad_top(&style_box,LV_STATE_DEFAULT,30);
    lv_style_set_pad_bottom(&style_box,LV_STATE_DEFAULT,30);
    lv_style_set_pad_left(&style_box,LV_STATE_DEFAULT,30);
    lv_style_set_pad_right(&style_box,LV_STATE_DEFAULT,30);
    lv_style_set_radius(&style_box, LV_STATE_DEFAULT, 10);
    lv_style_set_text_font(&style_box, LV_STATE_DEFAULT, &lv_font_montserrat_20);
    lv_style_set_text_color(&style_box, LV_STATE_DEFAULT, LV_COLOR_WHITE);
    /*create a page title*/
    lv_obj_t * page_title;
    page_title=lv_label_create(lv_scr_act(),NULL);
    lv_label_set_text(page_title,"Devices");
    lv_obj_add_style(page_title,LV_OBJ_PART_MAIN, &lv_style_title);
    lv_obj_align(page_title,NULL,LV_ALIGN_IN_TOP_MID,0,20);
    //style button//
    lv_style_init(&style_button);
    lv_style_set_bg_color(&style_button,LV_STATE_DEFAULT, LV_COLOR_CYAN);
    lv_style_set_bg_opa(&style_button,LV_STATE_DEFAULT, LV_OPA_TRANSP);
    lv_style_set_radius(&style_button,LV_STATE_DEFAULT,30);
    //line
    static lv_point_t line_points[] = {{0,0},{480,0}};
    //line object//
     lv_obj_t * line1;
     line1 = lv_line_create(lv_scr_act(), NULL);
     lv_line_set_points(line1, line_points, 2);
     lv_obj_add_style(line1,LV_LINE_PART_MAIN, &style_line);
     lv_obj_align(line1, page_title, LV_ALIGN_OUT_BOTTOM_MID, 0, 20);
     //page
     lv_obj_t *  page = lv_page_create(lv_scr_act(), NULL);
     //lv_obj_set_pos(page, 10, 10);
     lv_obj_set_size(page, 480, 750);
     lv_obj_add_style(page, LV_PAGE_PART_BG, &style_page);
     lv_page_set_scrlbar_mode(page, LV_SCRLBAR_MODE_OFF );
     lv_page_set_scrollable_fit2(page, LV_FIT_TIGHT, LV_FIT_TIGHT);
     lv_obj_align(page, line1, LV_ALIGN_IN_TOP_MID, 0, 10);
     for(int i=0;i<30;i++){
         if(arr_device_name[i]!=NULL && arr_device_id[i]!=NULL && arr_device_type[i]!=NULL && arr_device_client[i]!=NULL){
             char name[50];
             char id[50];
             char type[50];
             char deviceclient[50];
             strcpy(name,arr_device_name[i]);
             strcpy(id,arr_device_id[i]);
             strcpy(type,arr_device_type[i]);
             strcpy(deviceclient,arr_device_client[i]);
             char data[256];
             snprintf(data,256,"%s-%s-%s-%s",name,id,type,deviceclient);
             //creating array for passing string
             char* str_device = malloc(strlen(data)+1);
             strcpy(str_device, data);
             char *array_device[] = {};
             char * ( *ptr )[] = &array_device;
             ( *ptr )[i] = str_device;
             // add an area
             lv_obj_t * area = lv_obj_create(page, NULL);
             lv_obj_set_user_data(area,array_device[i]);
             lv_obj_set_size(area, 450, 150);
             lv_obj_add_style(area, LV_OBJ_PART_MAIN, &style_box);
             lv_obj_align(area, NULL, LV_ALIGN_OUT_BOTTOM_MID, 0, 20);
             // adding stuff to area
             //devicename
             devicename = lv_label_create(area, NULL);
             lv_label_set_recolor(devicename, true);
             lv_label_set_text(devicename,arr_device_name[i]);
             lv_obj_align(devicename,NULL,LV_ALIGN_IN_TOP_LEFT,10,10);
             //devicetype
             lv_obj_t * devicetype = lv_label_create(area, NULL);
             lv_label_set_recolor(devicetype, true);
             lv_label_set_text(devicetype,arr_device_type[i]);
             lv_obj_align(devicetype,NULL,LV_ALIGN_IN_TOP_MID,0,10);
             //client
             lv_obj_t * client = lv_label_create(area, NULL);
             lv_label_set_recolor(client, true);
             lv_label_set_text(client,arr_device_client[i]);
             lv_obj_align(client,NULL,LV_ALIGN_IN_TOP_RIGHT,-10,10);
             //extra widget
             if(strcmp(arr_device_type[i], "dimmer")==0){
                 //label
                 slider_label = lv_label_create(area, NULL);
                 lv_label_set_text(slider_label, "Level:58%");
                 lv_obj_set_auto_realign(slider_label, true);
                 lv_obj_add_style(slider_label,LV_OBJ_PART_MAIN, &lv_style_text);
                 lv_obj_align(slider_label, NULL, LV_ALIGN_CENTER, 0, 10);
                }else if(strcmp(arr_device_type[i],"Switch")==0){
                    //label
                    switch_label = lv_label_create(area, NULL);
                    lv_label_set_text(switch_label, "State:Off");
                    lv_obj_set_auto_realign(switch_label, true);
                    lv_obj_add_style(switch_label,LV_OBJ_PART_MAIN, &lv_style_text);
                    lv_obj_align(switch_label, NULL, LV_ALIGN_CENTER, 0, 10);
                }else if(strcmp(arr_device_type[i], "Thermostat")==0){
                    lv_obj_t * widget = lv_label_create(area, NULL);
                    lv_label_set_text(widget, "Temperature:20°C");
                    lv_label_set_recolor(widget, true);
                    lv_obj_add_style(widget,LV_OBJ_PART_MAIN, &lv_style_text);
                    lv_obj_align(widget,NULL,LV_ALIGN_CENTER,0,10);
                }else if(strcmp(arr_device_type[i],"Smart plug")==0){
                    //label
                    smart_plug_label = lv_label_create(area, NULL);
                    lv_label_set_text(smart_plug_label, "State:Off");
                    lv_obj_set_auto_realign(smart_plug_label, true);
                    lv_obj_add_style(smart_plug_label,LV_OBJ_PART_MAIN, &lv_style_text);
                    lv_obj_align(smart_plug_label,NULL,LV_ALIGN_CENTER,0,10);
                lv_obj_set_click(area, true);
                lv_obj_set_drag_parent(area, true);
                lv_obj_set_event_cb(area, page_event_handler);
static void page_event_handler(lv_obj_t * area, lv_event_t event)
        char * user_data=lv_obj_get_user_data(area);
        printf("user data from area:%s\n",user_data);
        char * devicename_split = strtok(user_data, "-");
        char * deviceid_split = strtok(NULL, "-");
        char * devicetype_split = strtok(NULL, "-");
        char * deviceclient_split = strtok(NULL, "-");
        printf( "---str_split1:%s\n", devicename_split );
        printf( "---str_split2:%s\n", deviceid_split );
        printf( "---str_split3:%s\n", devicetype_split );
        printf( "---str_split4:%s\n", deviceclient_split );
output
On 1st Click
user data from area:Living room-9-Switch-Philips
---str_split1:Living room
---str_split2:9
---str_split3:Switch
---str_split4:Philips
On 2nd Click(Got only Living Room)
---str_split2:(null)
---str_split3:(null)
---str_split4:(null)
The code is quite complex, so it’s a bit difficult to decode, but your use of array_device looks suspicious. I suspect it is going out of scope.
i am getting below values from my db using curl and json.
str_split2:9
str_split3:Switch
str_split4:Philips
i am sending these values to new screen called room_devices. in this page i want to display all these values as a custom list(for custom list i am using area)
is there any alternate to do such custom list and get full data as above
I agree with @embeddedt. array_device lives only in the for loop and its pointer will be invalid outside of the loop.
