Lv_obj_set_scroll_snap_y(obj, LV_SCROLL_SNAP_END) abnormal
I want to implement aligned scrolling, but there may be an issue of excessive scrolling at the top
Sample Code:
import display_driver
import lvgl as lv
Show an example to scroll snap
panel = lv.obj(lv.scr_act())
panel.set_size(100, 200)
panel.set_scroll_snap_y(lv.SCROLL_SNAP.END)
panel.set_flex_flow(lv.FLEX_FLOW.COLUMN)
panel.center()
for i in range(6):
btn = lv.btn(panel)
btn.set_size(60, 50)
label = lv.label(btn)
label.set_text("a {:d}".format(i))
label.center()
panel.update_snap(lv.ANIM.ON)
Hi @cwd,
Thanks for opening this topic.
Instead of using SCROLL_SNAP.END, you should use SCROLL_SNAP_START.
Reference : Scrolling | LVGL Open
