Aligning a label with another label using any of the …OUT… enums does not appear to be working (for example LV_ALIGN_OUT_RIGHT_TOP). If I used any of the IN enums they do indeed work as expected. Am i doing something wrong?
Visual Studio simulation.
In my case alignment with the LV_ALIGN_OUT_RIGHT_TOP on its parent label, but none of the OUT enums appear to work. Label text is not shown!
See below code
Here is a simplified version of my code which shows the problem
static void alignment_demo(lv_obj_t* parent)
lv_obj_t* container = lv_cont_create(parent, NULL);
lv_obj_align_origo(container, NULL, LV_ALIGN_CENTER, 0, 0);
lv_cont_set_layout(container, LV_LAYOUT_COL_M);
lv_cont_set_fit(container, LV_FIT_TIGHT);
static lv_style_t bigFont;
lv_style_copy(&bigFont, &lv_style_plain);
bigFont.text.font = &lv_font_roboto_28;
lv_obj_t* label1 = lv_label_create(container, NULL);
lv_label_set_text(label1, "Hello World");
lv_label_set_style(label1, LV_LABEL_STYLE_MAIN, &bigFont);
lv_obj_t* label2 = lv_label_create(container, NULL);
lv_label_set_text(label2, "==================================");
lv_obj_t* label3 = lv_label_create(label1, NULL);
lv_label_set_style(label3, LV_LABEL_STYLE_MAIN, &lv_style_plain);
lv_label_set_text(label3, "!!!!");
lv_obj_align(label3, NULL, LV_ALIGN_OUT_RIGHT_TOP, 0, 0);
//lv_obj_realign(label3);
This is what I am getting:
This is what I was expecting to see. I know I could achieve similar by having another container which is horizontally aligned but I want, in this example, the text “Hello World” to be centred and the smaller font text “!!!” to be aligned to the top right.
If I change the alignment to be INternal (LV_ALIGN_IN_TOP_RIGHT) then it does as I would expect:
