Hello everyone, I’m new to this area, I’m having big problems with building lv_micropython, the problem itself is that there is no up-to-date information about what version this or that Git submodule supports.
What do I have:
- esp32-s3-whroom-1
- display st7789
- esp-idf
- lv_micropython
- python 3.12 and 3.9
The problem itself is that initially I tried to build with esp-idf v5.4, the current version for today, I also downloaded the lv_micropython master branch (GitHub - lvgl/lv_micropython: Micropython bindings to LVGL for Embedded devices, Unix and JavaScript) and did not change anything in it, while building there are problems typical (as I understand) version transition errors, for example esp_adc_cal, then read the documentation specifically for the esp32 port (lv_micropython/ports/esp32/README.md at master · lvgl/lv_micropython · GitHub) I saw that esp-idf v4.4 is used (specifically for esp32s3) switched to version 4.4 but during installation I get python errors like:
Collecting gevent<2.0,>=1.2.2 (from gdbgui==0.13.2.0->-r /home/user/esp/esp-idf/requirements.txt (line 22))
Using cached gevent-1.5.0.tar.gz (5.3 MB)
Installing build dependencies ... done
Getting requirements to build wheel ... error
error: subprocess-exited-with-error
× Getting requirements to build wheel did not run successfully.
│ exit code: 1
╰─> [319 lines of output]
Compiling src/gevent/resolver/cares.pyx because it changed.
[1/1] Cythonizing src/gevent/resolver/cares.pyx
performance hint: src/gevent/libev/corecext.pyx:1291:5: Exception check on '_syserr_cb' will always require the GIL to be acquired.
Possible solutions:
Switched to python version 3.9 and the environment was installed.
After which I went to the lv_micropython directory and did everything according to the instructions:
- I activate the esp-idf environment
~/esp-idf/export.sh
Setting IDF_PATH to '/home/user/esp/esp-idf'
Detecting the Python interpreter
Checking "python" ...
Python 3.9.0
"python" has been detected
Adding ESP-IDF tools to PATH...
Using Python interpreter in /home/user/.espressif/python_env/idf4.4_py3.9_env/bin/python
Done! You can now compile ESP-IDF projects.
Go to the project directory and run:
idf.py build
- Then in the lv_micropython directory
cd lv_micropython
git submodule update --init --recursive lib/lv_bindings
make -C mpy-cross
CC ../shared/runtime/gchelper_generic.c
LINK build/mpy-cross
text data bss dec hex filename
324740 13888 856 339484 52e1c build/mpy-cross
make: выход из каталога «/home/user/work/lv_micropython/mpy-cross»
- Switch to the esp32 port
cd ports/esp32
make submodules
make BOARD=GENERIC_S3
- And I get a huge error output like
Building C object esp-idf/mai...lv_bindings/driver/esp32/modrtch.c.obj
FAILED: esp-idf/main/CMakeFiles/__idf_main.dir/home/user/work/lv_micropython/lib/lv_bindings/driver/esp32/modrtch.c.oBuilding C object esp-idf/mai.../lv_bindings/driver/esp32/espidf.c.obj
FAILED: esp-idf/main/CMakeFiles/__idf_main.dir/home/user/work/lv_micropython/lib/lv_bindings/driver/esp32/espidf.c.obj bj
Building C object esp-idf/mai...s/__idf_main.dir/__/__/lv_espidf.c.obj
FAILED: esp-idf/main/CMakeFiles/__idf_main.dir/__/__/lv_espidf.c.obj
/home/user/work/lv_micropython/ports/esp32/build-GENERIC_S3/lv_espidf.c:6526:20: warning: initialization discards 'const' qualifier from pointer target type [-Wdiscarded-qualifiers]
.mp_obj_type = &mp_lv_SH2LIB_DATA_FLAG_type_base,
/home/user/work/lv_micropython/ports/esp32/build-GENERIC_S3/lv_espidf.c:6569:20: warning: initialization discards 'const' qualifier from pointer target type [-Wdiscarded-qualifiers]
.mp_obj_type = &mp_lv_SH2LIB_DATA_RECV_type_base,
cc1: some warnings being treated as errors
[1418/1733] Building C object esp-idf/...Files/__idf_main.dir/__/__/lv_mp.c.obj
ninja: build stopped: subcommand failed.
ninja failed with exit code 1
-e See https://github.com/micropython/micropython/wiki/Build-Troubleshooting
make: *** [Makefile:52: all] Ошибка 1
I’ve been struggling with this for two weeks now and I can’t put it together, no matter what I tried (and tried to use legacy export, but for some reason it doesn’t export normally).
Moreover, if you assemble it simply like make, it assembles normally, but you can’t flash it, I would like to compile it specifically for esp32s3
The main problems are that the documentation does not indicate anywhere which current version of this or that software to use for assembly and I do not understand how to assemble correctly.
