“Pretty” layouts
C in general
Make the mighty container obey my layout directives!
See below
Here’s my test for LV_LAYOUT_PRETTY_TOP/MID/BOTTOM.
lv_obj_t *cont = lv_cont_create(base, NULL);
/* Fixed height container */
lv_cont_set_fit2(cont, LV_FIT_PARENT, LV_FIT_NONE);
lv_obj_set_style_local_bg_color(cont, LV_CONT_PART_MAIN, LV_STATE_DEFAULT, LV_COLOR_GRAY);
lv_obj_set_height(cont, 150);
/* This has no effect .. top, mid, bottom */
lv_cont_set_layout(cont, LV_LAYOUT_PRETTY_MID);
lv_obj_t *edit_btn = lv_btn_create(cont, NULL);
Clipped away: Here I adjust the button to desired form; Diameter 34, margins 4 (horiz.) and 2 (vert.)
/* Nine buttons altogether */
lv_btn_create(cont, edit_btn);
Here’s the result. It is always similar with PRETTY layouts TOP/MID/BOTTOM. Am I missing now something? With i.e MID version I’d expect to see equal spacing in vertical direction too…
Thanks!
I tend to position things by hand, so I may not be much help, but maybe you need to call lv_cont_set_layout after creating the buttons?
I think I tried that too → no help. I traced the execution a little and it really always re-positions all after adding a single item. That makes sense. I will however check tomorrow what happens when I place the layout call at the end.
Sir @kisvegabor has created this, let’s hear what he has to say (should he had some spare time…)
Thank you!
@embeddedt, I checked this and as I recalled, it does not affect whether I call lv_cont_set_layout() before or after creating objects.
I have to stick fixing things manually for the moment, but I look forward hearing @kisvegabor’s opinion, as these automatic layout are super handy at certain places. Mmm, maybe I’ll get an opportunity fix this should there be a bug
MID/TOP/BOTTOM means what to do when the objects has different height. Align their middle line bottom or to top (in the same row) .
I also could use a “real middle” layout in some projects so I’m open to find new useful layouts and/or update the existing ones.
@kisvegabor Have you ever considered implementing flexbox or a similar layout implementation in LVGL? It tends to be quite "flex"ible (excuse the pun) for these kinds of situations.
OK, so apparently there isn’t (yet) suitable alignment option - Flexboxes “align items center” would be such
It sounds great! Using the flexbox-approach would simply layouts yet make them more versatile. Besides, we already made a good friendship with CSS in the styles.
Getting more ideas from there is definitely a good idea.
Maybe we can join fit and layout into one property.
We already have an open issue for reworking layouts.
Let’s continue there. @embeddedt Could you add a comment with idea of flexbox.
