i tried to clear 6 seperate text labels simultaneously which made my code to restart (right from “void setup” ).
esp32s3
8.3.11
clear 6 seperate text labels simultaneously.
i have pasted relevant parts of my code below for reference.
void percent() {
if (readString.length() > 0) {
Serial2.print(readString);
String messageend = readString.substring(readString.length() - 6, readString.length());
const char* str502 = messageend.c_str();
String messagestart = readString.substring(0, 18);
const char* str501 = messagestart.c_str();
String comp = readString.substring(0, 19);
const char* str1 = comp.c_str();
String compslid = readString.substring(0, 22);
const char* str11 = compslid.c_str();
const char* str10 = readString.c_str();
if (strcmp(str1, str2) == 0) {
Serial2.println("blue");
readString.replace(" ", "");
readString.replace("$", "");
String hexDigits = readString.substring(readString.length() - 4, readString.length());
long decimalValue = strtol(hexDigits.c_str(), NULL, 16);
Serial2.println(decimalValue);
char formattedValue[10];
sprintf(formattedValue, "%05.2f", (float)decimalValue / 100.0);
Serial2.println(formattedValue);
label_xy();
lv_label_set_text_fmt(ui_Label801, "%s %%", formattedValue);
if (strcmp(str1, str4) == 0) {
label_xy1();
lv_label_set_text_fmt(ui_Label802, "%s %%", formattedValue);
if (strcmp(str1, str5) == 0) {
label_xy2();
lv_label_set_text_fmt(ui_Label803, "%s ", formattedValue);
if (strcmp(str1, str6) == 0) {
label_xy3();
lv_label_set_text_fmt(ui_Label804, "%s %%", formattedValue);
if (strcmp(str1, str7) == 0) {
// Serial2.print(decimalValue1);
label_xy4();
lv_label_set_text_fmt(ui_Label805, "%s %%", formattedValue);
if (strcmp(str1, str8) == 0) {
label_xy5();
lv_label_set_text_fmt(ui_Label806, "%s °C", formattedValue);
if (strcmp(str10, str15) == 0) {
goto_widget_flag = 71;
Serial2.println("stop");
readString = "";
inside void loop ---
lv_task_handler();
lv_timer_handler();
if (Serial2.available() > 0) {
char c = Serial2.read();
if (c == '\n') {
percent();
else {
readString += c;
if (goto_widget_flag == 71) {
lv_label_set_text_fmt(ui_Label801, " ");
goto_widget_flag = 72;
if (goto_widget_flag == 72) {
lv_label_set_text_fmt(ui_Label802, " ");
goto_widget_flag = 73;
if (goto_widget_flag == 73) {
lv_label_set_text_fmt(ui_Label803, " ");
goto_widget_flag = 74;
if (goto_widget_flag == 74) {
lv_label_set_text_fmt(ui_Label804, " ");
goto_widget_flag = 75;
if (goto_widget_flag == 75) {
lv_label_set_text_fmt(ui_Label805, " ");
goto_widget_flag = 76;
if (goto_widget_flag == 76) {
lv_label_set_text_fmt(ui_Label806, " ");
goto_widget_flag = 1000;
## Screenshot and/or video
here is a screenshot of the output printed on the serial monitor when the code restarts.
![LvglWidgets-LVGL-7.0 _ Arduino IDE 2.3.2 17-04-2024 17_28_11|690x356](upload://kO5gjZE5UE698pm3XBP9gLXMu1Y.png)
