Show log … Seems is big problem for you do simple think copy code from message run it and show return. For me in VS Code is this 3 minute job.
next step is this , etc. FYI
Concerning log, there is only: ---- Opened the serial port COM4 ----
Counter: 0
I will do next step.
Counter 0 only and nothink after click button??? Then your system completely dont work not waste time…
There was Counter: 0 at start,
after each click value increase by 1:
Counter: 1
Counter: 2,
but counting was very fast 115200 Baud rate.
Your the last code I applyed. There was not replaced label with Label2 on screen. Fathermore: counter was not increased after each click.
have you this aplyed and is very fast , are you sure ???
Yes, but there was other error.
Now is screen blinking about 0.5Hz,
but I have log:
LVGL demo setup
LVGL Setup done
Counter: 0
Counter: 0
Label 2: Guru Meditation Error: Core 1 panic’ed (LoadProhibited). Exception was unhandled.
Core 1 register dump:
PC : 0x401270af PS : 0x00060830 A0 : 0x800d1eb7 A1 : 0x3ffb2250
A2 : 0x00000000 A3 : 0x3f40015b A4 : 0x0000000a A5 : 0x00000000
A6 : 0x00000000 A7 : 0x0000008f A8 : 0x80101c64 A9 : 0x3ffb2230
A10 : 0x00000009 A11 : 0x3f40015b A12 : 0x00000001 A13 : 0x3ffb2120
A14 : 0x0000000b A15 : 0x3ffb2120 SAR : 0x0000001b EXCCAUSE: 0x0000001c
EXCVADDR: 0x0000002c LBEG : 0x400866e9 LEND : 0x400866f9 LCOUNT : 0xfffffffd
Backtrace: 0x401270ac:0x3ffb2250 0x400d1eb4:0x3ffb2270 0x401043f5:0x3ffb2290
ELF file SHA256: d0a26504df3835b8
Place your exact copy of loop code here
void loop() {
static int lastcounter;
static lv_obj_t * ui_Label2;
static int counter = 0;
static int lastTick = 0;
//Update the tick timer
lv_tick_inc(millis() - lastTick); //Update the tick timer. Tick is new for LVGL 9
lastTick = millis();
lv_timer_handler(); //Update the UI
delay(5);
if(lastcounter!=counter) {
Serial.print("Counter: ");
Serial.println(counter);
lastcounter=counter;
if(! ui_Label2) {
ui_Label2 = lv_label_create(lv_screen_active());
lv_obj_set_pos(ui_Label2, 127, 19);
lv_obj_set_size(ui_Label2, LV_SIZE_CONTENT, LV_SIZE_CONTENT);
lv_obj_add_flag(ui_Label2, LV_OBJ_FLAG_OVERFLOW_VISIBLE);
lv_obj_set_style_text_font(ui_Label2, &lv_font_montserrat_26, LV_PART_MAIN | LV_STATE_DEFAULT);
lv_label_set_text_fmt(ui_Label2, "%d", counter);
printf("Counter: %d\n", counter);
Serial.print("Label 2: ");
Serial.println(lv_label_get_text(ui_Label2));
seems you are better then i end with you … this line hangs mcu because label dont exist is created only on first change counter as next on display no replace. Learn basic C language or go back to LEGO land.
Next absurd line is
BYE
Sorry Milan, I like lego, I was using wirering Arduino language and now I go to eez studio. But I am technician and now litle slow, my age is 78 and my english is poor. I understand you, if you have no power to help mi, it is OK. But problem is solved - see the end of this message.
I removed 2 problem lines. Now log is:
LVGL demo setup
LVGL Setup done
Counter: 0
Counter: 0
ELF file SHA256: 8fda0a4532b4f5c7
Rebooting…
Maybe the problem is nearly solved. There is next label above NUM on the screen. This new label is counter number. I need just to clear old label NUM.
try change to
static lv_obj_t * ui_Label2 = NULL;
and if line cahge to
if( ui_Label2 == NULL) {
and around your trouble maybe in EEZ you use label name incorectly , i dont have EEZ , but basic rule is no space in names . Maybe simpler for you will try Squareline instead EEZ.
Your last code lines did not help.
But it is nearly OK. In your code was set position for label2 - counter value +30 px higher then is NUM. I place it in the same position and now is label overlapped with NUM and counter.
I agree that problem could be in EEZ to PlatformIO, because I was using Copilot with many alternatives and label was never replaced by mentioned function. This project was just test and learn and Thankyou very mach for your time.
