twaik
July 17, 2020, 6:01pm
1
lv_keyboad changes size and position of parent object on lv_obj_set_width call, it does not matter if it is lv_page, lv_cont or lv_win.
lv_sim_eclipse_sdl
7.0.0
Integrate lv_keyboard with custom mapping into a widget without resizing it.
Created a custom lv_cont based widget with lv_label and lv_keyboard.
lv_terminal.zip (3.7 KB)
Usage: call lv_terminal() instead of lv_demo_widgets() in lv_sim_eclipse_sdl’s main function.
Without trying to set position:
After setting width:
twaik
July 18, 2020, 7:40am
2
Maybe it is a bug and it should be moved to another forum.
Is autofit disabled on the container? It may be enabled by default. https://docs.lvgl.io/latest/en/html/widgets/cont.html#autofit
twaik
July 19, 2020, 3:40pm
4
I do not think it is related to autofit. Behaviour of lv_keyboard depends on parent object. When I do lv_keyboard_create(lv_scr_act(), NULL) everything is OK, it reports size LV_POS_HORxLV_POS_VER/2. But if I do lv_keyboard_create(cs, NULL) where cs is fullscreen lv_cont it has margins or padding on right and left edges. Changing autofit value does not help. Default fit value is (0,0,0,0).
twaik
July 19, 2020, 5:24pm
5
Looks like a problem is a container’s padding style. This line fixes my problem and I still do not know if it creates new.
lv_obj_t * cs = lv_cont_create(par, copy);
lv_obj_set_style_local_pad_hor(cs, LV_CONT_PART_MAIN, LV_STATE_DEFAULT, 0);
Will it create problems?
If you don’t want any space between the edge of the container and the keyboard, then your solution is the correct one.
