First of all, congratulations for your amazing library !
I’m using LVGL v8.4 with a Makerfabs ESP32-S3 Parallel TFT with Touch 3.5’’ ILI9488 board
(https://www.makerfabs.com/esp32-s3-parallel-tft-with-touch-ili9488.html).
Display is working great, but I can’t make LVGL to work using LV_INDEV_TYPE_KEYPAD input device type with a Duppa I2C NavKey v2.1 controller (with neither the directional part of the controller, nor the rotary encoder part of the controller). Rotary encoder part of the NavKey work well, just by changing the input device type to LV_INDEV_TYPE_ENCODER (not changing anything else to the code), but the directional part still doesn’t work.
I’ve read the LVGL documentation over and over again, but I can’t find the issue.
Here is the input device read callback function :
void read_navkey(lv_indev_drv_t *indev, lv_indev_data_t *data)
navkey.updateStatus();
if (navkey.readStatus(i2cNavKey::CTRP))
printf("Push\n");
printf("Release\n");
int CounterValue = navkey.readCounterInt();
if(CounterValue != 0)
data->enc_diff = CounterValue;
printf("Diff: %d\n", data->enc_diff);
// Reset the navkey rotary encoder to zero
navkey.writeCounter(0);
if (navkey.readStatus(i2cNavKey::UPP))
// data->key = LV_KEY_UP;
data->key = LV_KEY_PREV;
printf("UP\n");
if (navkey.readStatus(i2cNavKey::DNP))
// data->key = LV_KEY_DOWN;
data->key = LV_KEY_NEXT;
printf("DOWN\n");
if (navkey.readStatus(i2cNavKey::RTP))
data->key = LV_KEY_RIGHT;
printf("RIGHT\n");
if (navkey.readStatus(i2cNavKey::LTP))
data->key = LV_KEY_LEFT;
printf("LEFT\n");
I also have some questions :
When using (for example)
as I do in the callback function, should it make the focus change to the previous object in the input device group (that I previously set) on the screen ? -
Should
also work with LV_INDEV_TYPE_KEYPAD input device type set ? -
Should all
data->key
still work with LV_INDEV_TYPE_ENCODER input device type set ?
Thank you very much in advance for your help.
