I have an Arduino program based on LVGLDemo. When the program enters the lv_img_set_src it hangs. I know that it is this function that creates a problem because a print statement prior to this function is being executed. The error log shows this
18:01:06.152 -> [Trace] (7.266, +1) lv_mem_alloc: allocating 56 bytes (in lv_mem.c line #127)
18:01:06.152 ->
18:01:06.152 -> [Trace] (7.266, +0) lv_mem_alloc: allocated at 0x24003a18 (in lv_mem.c line #160)
18:01:06.152 ->
I think it has something to do with this call in lv_mem.c
#if LV_MEM_CUSTOM == 0
void * new_p = lv_tlsf_realloc(tlsf, data_p, new_size);
#else
void * new_p = LV_MEM_CUSTOM_REALLOC(data_p, new_size);
if(new_p == NULL) {
LV_LOG_ERROR("couldn't allocate memory");
return NULL;
MEM_TRACE("allocated at %p", new_p);
return new_p;
My memory settings in lv_conf.h are as follows
/*1: use custom malloc/free, 0: use the built-in `lv_mem_alloc()` and `lv_mem_free()`*/
#define LV_MEM_CUSTOM 0
//#define LV_MEM_SIZE (48U * 1024U) /*[bytes]*/ //origineel
#define LV_MEM_SIZE (128U * 1024U) /*[bytes]*/
#if LV_MEM_ADR == 0
#undef LV_MEM_POOL_INCLUDE
#undef LV_MEM_POOL_ALLOC
#else /*LV_MEM_CUSTOM*/
#define LV_MEM_CUSTOM_INCLUDE <stdlib.h> /*Header for the dynamic memory function*/
#define LV_MEM_CUSTOM_ALLOC malloc
#define LV_MEM_CUSTOM_FREE free
#define LV_MEM_CUSTOM_REALLOC realloc
#endif /*LV_MEM_CUSTOM*/
I also tried with #define LV_MEM_CUSTOM 1 but to no avail.
Arduino G1 using Arduino IDE editor
8.3.11
I want to understand why lv_img_set_src is hanging.
Tried different memory settings in lv_conf.h
This is where it goes wrong
Serial.println("Preparing image");
lv_obj_t * img1 = lv_img_create(obj);
Serial.println("1");
//lv_lodepng_init();
//lv_png_init(); niet herkend door de compiler
lv_obj_set_size(img1, 32, 32);
Serial.println("2");
lv_obj_set_pos(img1, 130, 70);
Serial.println("3");
for (int i=0;i<20;i++) {Serial.println();}
//lv_img_set_src(img1, &img_arduinologo); //This one displays perfectly on the screen
lv_img_set_src(img1, "S:/LOGO.png"); // tried different calls S:LOGO.PNG S:/LOGO.PNG etc
Serial.println("Done Preparing image");
Code hangs at lv_img_set_src.
Suggestions are welcome.
