When using LVGL v8 to load images converted with the LVGL Image Converter (in .bin format), the image displays correctly by default, but becomes distorted or appears “flipped”/“mirrored” when rotated using lv_img_set_angle().
esp32c3
- LVGL version: v8
- Image format: generated using LVGL’s official Image Converter, output as
.bin - Color format:
LV_IMG_CF_TRUE_COLOR(orTRUE_COLOR_ALPHA) - Image renders correctly before rotation
- After rotation, the image appears as a thin line or looks like it’s been “flipped” or “mirrored”
- bin file format images can be rotated correctly
The generated C code image can be rotated normally, but the bin image cannot
// 获取当前屏幕
lv_obj_t *scr = lv_disp_get_scr_act(disp);
// 创建图像对象
lv_obj_t *img = lv_img_create(scr);
lv_img_set_src(img, "A:/littlefs/moiw_2014.bin"); // 使用LittleFS中的图像文件
// lv_img_set_src(img, &moiw_2014); // 使用LittleFS中的图像文件
// 设置图像中心对齐
lv_obj_center(img);
// 允许旋转和缩放(开启变换属性)
lv_img_set_pivot(img, 100 ,100); // 设定旋转中心
lv_img_set_angle(img, 0); // 初始角度:0°
// 创建动画旋转图像
lv_anim_t a;
lv_anim_init(&a);
lv_anim_set_var(&a, img);
lv_anim_set_values(&a, 0, 3600); // 单位是0.1°,3600 = 360°
lv_anim_set_time(&a, 3000); // 3秒一圈
lv_anim_set_repeat_count(&a, LV_ANIM_REPEAT_INFINITE);
lv_anim_set_exec_cb(&a, (lv_anim_exec_xcb_t)lv_img_set_angle);
lv_anim_start(&a);
