i build a c++ Applicaion with a lvgl GUI, which shows me errors and data of devices. The Data and Errors are received over a messageBus. An sometimes i close a MessageBox the Application crashes in _lv_event_mark_deleted Function.
I use the SDL Simulator on a Ubuntu 20.04 VirtualMachine and a i.MX 6 board with the GCC-Compiler.
Tried with 8.0, 8.2 and 8.3.
I would like to Show a MessageBox every Time an Error occurs from the messageBus. This is works fine.
If the Error disapears (event from the messageBus) the MessageBox should be closed. Here is the Problem. Sometimes, when the MessageBox is closed, my Application crashes in the _lv_event_mark_deleted Function.
I tried to use different widgets
- the
lv_msgbox(modal / non Modal) - self created MessageBox based on
lv_obj
I tried to use different screens and different layers (top/sys layer)
I tried to use lv_obj_del_async and lv_obj_del
I tried to debug with enabling the Log-Messages (LV_LOG_...)
I wrote a Wrapper Class for all lv_obj that were created. This class has an destroy Method to delete the lvgl object. I use the lv_obj_is_valid Method to check, that a Object is valid to delete.
The Method shows the synchron way for the Deletion. In this case the code crashes in the line with lv_obj_del(m_widget);
void BaseLvglWidget::destroyLvWidget()
if(m_widget and (not m_isDeleted) and lv_obj_is_valid(m_widget))
m_isEnabled = false; // Block Signal publishs
m_isDeleted = true; // Avoid using the Object after Deletion
In the Async Method the Crash is during the run of the lv_timer_handler
Can someone help me or guide me in the right direction to solve the Problem?
