Lv_event_get_user_data - pass and receive a string from "lv_obj_add_event_cb"
Hi guys
Parameters:
LVGL 8.3.10
Arduino IDE 2.2.1 Linux
ESP32
I’m trying to pass a string information from “lv_obj_add_event_cb” and to receive the same value inside “lv_event_get_user_data” but it’s bringing me an invalid character value.
First function:
char * wifiName;
wifiName = "abc";
Serial.print("I'll send: ");
Serial.println(wifiName);
network = lv_list_add_btn(list1, LV_SYMBOL_WIFI, wifiNameA.c_str());
lv_obj_add_event_cb(network, list_event_handler, LV_EVENT_CLICKED, &wifiName);
Second function:
static void list_event_handler(lv_event_t * e)
   char * userdata = (char*)lv_event_get_user_data(e);
   // char * vai = (char*)lv_obj_get_user_data(e);
    Serial.print("I recieved: ");
    Serial.println((char*)lv_event_get_user_data(e));
    Serial.println((char*)userdata);
        lv_example_textarea_2();
What I’m doing wrong here?
Thank so much
Best Regards
Sho code where and how you declare wifiName
HI @mmar22
I updated the first post…
Thank so much
is complete bad in C maybe in C++ ok assign cont string, but as local cant be used in cb func as user data. Create it global and for safe
char wifiname[10];
Hi @Marian_M
Thank so much… Almost solved. I can pass the information, but only works for last item of list.
Can you please help me to understand my fault?
  const char *userdata = (char*)lv_event_get_user_data(e);
  Serial.println(userdata);
void scan_wifi(){
  lv_obj_t * list1;
  list1 = lv_list_create(tab3);
  lv_obj_set_size(list1, 180, 220);
  lv_obj_center(list1);
  String wifiNameAndSignal = "";
  char *wifiName[0];
  int n = WiFi.scanNetworks();
  Serial.println("scan done");
  if (n == 0) {
      Serial.println("no networks found");
      lv_list_add_text(list1, "No Networks found :(");
  } else {
    Serial.print(n);
    Serial.println(" networks found");
    lv_list_add_text(list1, "Networks found:");
    for (int i = 0; i < n; ++i) {
      *wifiName = {};
      wifiNameAndSignal = WiFi.SSID(i) + " (" + WiFi.RSSI(i) + " db)";
      String wifiNameOnly = WiFi.SSID(i);
      *wifiName = (char*)wifiNameOnly.c_str();
      Serial.println(*wifiName);
      network = lv_list_add_btn(list1, LV_SYMBOL_WIFI, wifiNameAndSignal.c_str());
      lv_obj_add_event_cb(network, list_event_handler, LV_EVENT_CLICKED, *wifiName);
      String LabelItem = (String)(i+1) + ": " + WiFi.SSID(i) + " (" + WiFi.RSSI(i) + "db)";
             LabelItem += (WiFi.encryptionType(i) == WIFI_AUTH_OPEN)?" ":"*";
      Serial.println(LabelItem);
      Serial.println("-------------------------------------------------------------------------------");
      delay(10);
  Serial.println("");
The Serial Monitor info:
scan done
11 Networks found
I'll send: NET0001
1: NET0001 (-52db)*
I'll send: NET0002
2: NET0002 (-56db)*
I'll send: NET0003
3: NET0003 (-57db)*
I'll send: NET0004
4: NET0004 (-59db)*
I'll send: NET0005
5: NET0005 (-61db)*
I'll send: NET0006
6: NET0006 (-75db)*
I'll send: NET0007
7: NET0007 (-76db)*
I'll send: NET0008
8: NET0008 (-83db)*
I'll send: NET0009
9: NET0009 (-84db)*
I'll send: NET00010
10: NET00010 (-84db)*
I'll send: DIRECT-8B-HP ENVY 7640 series
11: DIRECT-8B-HP ENVY 7640 series (-87db)*
I recieved: ����������?$9�?\��?
I recieved: DIRECT-8B-HP ENVY 7640 series
Thank so much
Best Regards
Still you mix chaos of C++ and C. But primary mistake is you create one wifiname pointer and many buttons with callbacks to one name, then result is last one name for all clicks.
THank so much
I 'll try to fix the languages here.
Best Regards
and you still place this inside func = local variable , that stop exist on func end. Then you cant use it in cb userdata.
