In short: while SDL2 used to abstract OS-depended things for PC drivers, user still needs to apply some OS-dependent actions in his code. It would be convenient to minimize such efforts (reduce to SDL2 install info only).
<tl;dr>
Currently, lv_drivers
works somehow. But it’s not enough convenient to create unified “emulator” code, build-able on different OS-es. For example, in PIO i’d like to just run “build with sdl2 backend” and don’t care about details.
Imagine, we have sdl2 lib/headers installed and available via PATH. What i would like:
- Have the same code in userspace for all platforms. Proper options should be detected automatically, inside of
lv_drivers
, transparently for user. - Option to force target platform (cross-compile to webassembly, for example)
- Use “standard” guards names to check platform, instead of custom ones.
- IMO name “monitor.*” is not enough descriptive. May be
sdl2_monitor.*
orsdl2_display.*
? The same for keyboards/mouse/… All this can be implemented via different kinds of backends. Prefixsdl_
could improve things. - Term “emulator” is confusing. That’s just a drivers for desktop OS. “PC drivers to develop GUI without bare metal” - IMO more easy to understand what is it. I’d suggest to review used terms in all docs.
Other questions:
- Why windows-related code has separate entry (
./windrv.*
)? - Why separate thread created, instead of
lv_task
use? IMO single-threaded app will note require those init kludges. Precision oflv_task
is medium, but should be ok for drivers.
Probably i misunderstand something. Sorry in advance if some questions are naive. Final goal is to make use of sdl2 more simple.
I’ve left aside some points, to focus on primary goal.
- In PIO i can detect OS via extra script (and add build vars), but i don’t like to use this feature without need (now it does not solve “how to keep userland code simple”).
- In PIO, it’s possible to automate windows sdl2 install to local project folder. Postponed until more high level questions solved.
