Lv_display_set_3rd_draw_buffer?
I’m looking for ways to speed lvgl up; it’s still very slow.
Does a 3rd buffer now work in lvgl 9.3 ? Here compilation fails because the second argument is not parsed correctly.
esp32s3, co5300 driver, 466*466 amoled display
esp-idf
9.3
Speed things up!
Going back to lvgl8 actually increases performance. So does setting a higher task priority in freertos. Still would like to use lvgl9 when possible.
here is my buffer setup during lvgl initialization:
uint8_t *buf1 = heap_caps_aligned_alloc(64, LVGL_BUFF_SIZE, MALLOC_CAP_DMA);
uint8_t *buf2 = heap_caps_aligned_alloc(64, LVGL_BUFF_SIZE, MALLOC_CAP_DMA);
uint8_t *buf3 = heap_caps_aligned_alloc(64, LVGL_BUFF_SIZE, MALLOC_CAP_DMA);
    assert(buf1);
    assert(buf2);
    assert(buf3);
lv_display_set_buffers(disp, buf1, buf2, LVGL_BUFF_SIZE, LV_DISPLAY_RENDER_MODE_PARTIAL);
lv_display_set_3rd_draw_buffer(disp, buf3);
Hi @qwerkus ,
Here is a link to another post which contains code to initialise three buffers…
Hope that helps.
Kind Regards,
Pete
Thanks to your example it compiles fine now; unfortunately it appears my driver (co5300) doesn’t support a third buffer (I’m stuck on a green screen with watchdog trigger by the driver), so this was probably just a waste of time.
