Lv_color_format_rgb565a8
Hi everyone,
I’m using LVGL v9.2 with an ESP32-S3 and an RGB LCD display via the esp_lcd_rgb_panel driver. My color format is set to LV_COLOR_FORMAT_RGB565A8 because I want to enable alpha transparency for blending.
However, transparency is not working as expected.
Can anyone help me figure out what might be missing or misconfigured?
Thanks in advance!
Seems you missunderstand somethink Color Format — LVGL 9.3 documentation
this latest , but older too dont have A8 framebuffers…
i can show you my code :
static bool example_notify_lvgl_flush_ready(esp_lcd_panel_handle_t panel, const esp_lcd_rgb_panel_event_data_t *event_data, void *user_ctx)
lv_display_t *disp = (lv_display_t *)user_ctx;
lv_display_flush_ready(disp);
return false;
static void example_lvgl_flush_cb(lv_display_t *disp, const lv_area_t *area, uint8_t *px_map)
esp_lcd_panel_handle_t panel_handle = lv_display_get_user_data(disp);
int offsetx1 = area->x1;
int offsetx2 = area->x2;
int offsety1 = area->y1;
int offsety2 = area->y2;
// pass the draw buffer to the driver
esp_lcd_panel_draw_bitmap(panel_handle, offsetx1, offsety1, offsetx2 + 1, offsety2 + 1, px_map);
lv_disp_flush_ready(disp);
static void example_increase_lvgl_tick(void arg)
Tell LVGL how many milliseconds has elapsed */
lv_tick_inc(EXAMPLE_LVGL_TICK_PERIOD_MS);
static void example_bsp_init_lcd_backlight(void)
gpio_config_t bk_gpio_config = {
.mode = GPIO_MODE_OUTPUT,
.pin_bit_mask = 1ULL << EXAMPLE_PIN_NUM_BK_LIGHT
ESP_ERROR_CHECK(gpio_config(&bk_gpio_config));
static void example_bsp_set_lcd_backlight(uint32_t level)
gpio_set_level(EXAMPLE_PIN_NUM_BK_LIGHT, level);
void task_lvgl_main(void *arg)
ESP_LOGI(TAG, "Turn off LCD backlight");
example_bsp_init_lcd_backlight();
example_bsp_set_lcd_backlight(EXAMPLE_LCD_BK_LIGHT_OFF_LEVEL);
ESP_LOGI(TAG, "Install RGB LCD panel driver");
esp_lcd_panel_handle_t panel_handle = NULL;
esp_lcd_rgb_panel_config_t panel_config = {
    .data_width = EXAMPLE_DATA_BUS_WIDTH,
    .psram_trans_align = 64,
    .num_fbs = EXAMPLE_LCD_NUM_FB,
    .clk_src = LCD_CLK_SRC_DEFAULT,
    .disp_gpio_num = EXAMPLE_PIN_NUM_DISP_EN,
    .pclk_gpio_num = EXAMPLE_PIN_NUM_PCLK,
    .vsync_gpio_num = EXAMPLE_PIN_NUM_VSYNC,
    .hsync_gpio_num = EXAMPLE_PIN_NUM_HSYNC,
    .de_gpio_num = EXAMPLE_PIN_NUM_DE,
    .data_gpio_nums = {
        EXAMPLE_PIN_NUM_DATA0,
        EXAMPLE_PIN_NUM_DATA1,
        EXAMPLE_PIN_NUM_DATA2,
        EXAMPLE_PIN_NUM_DATA3,
        EXAMPLE_PIN_NUM_DATA4,
        EXAMPLE_PIN_NUM_DATA5,
        EXAMPLE_PIN_NUM_DATA6,
        EXAMPLE_PIN_NUM_DATA7,
        EXAMPLE_PIN_NUM_DATA8,
        EXAMPLE_PIN_NUM_DATA9,
        EXAMPLE_PIN_NUM_DATA10,
        EXAMPLE_PIN_NUM_DATA11,
        EXAMPLE_PIN_NUM_DATA12,
        EXAMPLE_PIN_NUM_DATA13,
        EXAMPLE_PIN_NUM_DATA14,
        EXAMPLE_PIN_NUM_DATA15,
    .timings = {
        .pclk_hz = EXAMPLE_LCD_PIXEL_CLOCK_HZ,
        .h_res = EXAMPLE_LCD_H_RES,
        .v_res = EXAMPLE_LCD_V_RES,
        .hsync_back_porch = EXAMPLE_LCD_HBP,
        .hsync_front_porch = EXAMPLE_LCD_HFP,
        .hsync_pulse_width = EXAMPLE_LCD_HSYNC,
        .vsync_back_porch = EXAMPLE_LCD_VBP,
        .vsync_front_porch = EXAMPLE_LCD_VFP,
        .vsync_pulse_width = EXAMPLE_LCD_VSYNC,
        .flags = {
            .pclk_active_neg = true,
    .flags.fb_in_psram = true, // allocate frame buffer in PSRAM
ESP_ERROR_CHECK(esp_lcd_new_rgb_panel(&panel_config, &panel_handle));
ESP_LOGI(TAG, "Initialize RGB LCD panel");
ESP_ERROR_CHECK(esp_lcd_panel_reset(panel_handle));
ESP_ERROR_CHECK(esp_lcd_panel_init(panel_handle));
ESP_LOGI(TAG, "Turn on LCD backlight");
example_bsp_set_lcd_backlight(EXAMPLE_LCD_BK_LIGHT_ON_LEVEL);
ESP_LOGI(TAG, "Initialize LVGL library");
// create a lvgl display
lv_display_t *display = lv_display_create(EXAMPLE_LCD_H_RES, EXAMPLE_LCD_V_RES);
/*touch_screen*/
/* Create and set up at least one display before you register any input devices. */
lv_indev_t * indev = lv_indev_create();        /* Create input device connected to Default Display. */
lv_indev_set_type(indev, LV_INDEV_TYPE_POINTER);   /* Touch pad is a pointer-like device. */
lv_indev_set_read_cb(indev, lv_ft3663g_read);    /* Set driver function. */
/*touch_screen*/
// associate the rgb panel handle to the display
lv_display_set_user_data(display, panel_handle);
// set color depth
lv_display_set_color_format(display, EXAMPLE_LV_COLOR_FORMAT);
// create draw buffers
void *buf1 = NULL;
void *buf2 = NULL;
ESP_LOGI(TAG, "Allocate LVGL draw buffers");
// it's recommended to allocate the draw buffer from internal memory, for better performance
size_t draw_buffer_sz = EXAMPLE_LCD_H_RES * EXAMPLE_LVGL_DRAW_BUF_LINES * EXAMPLE_PIXEL_SIZE;
//buf1 = heap_caps_malloc(draw_buffer_sz, MALLOC_CAP_SPIRAM | MALLOC_CAP_8BIT); //origin
buf1 = heap_caps_malloc(draw_buffer_sz, MALLOC_CAP_SPIRAM | MALLOC_CAP_8BIT );
assert(buf1);
buf2 = heap_caps_malloc(draw_buffer_sz, MALLOC_CAP_SPIRAM | MALLOC_CAP_8BIT );
assert(buf2);
// set LVGL draw buffers and partial mode
lv_display_set_buffers(display, buf1, buf2, draw_buffer_sz, LV_DISPLAY_RENDER_MODE_PARTIAL);
// set the callback which can copy the rendered image to an area of the display
lv_display_set_flush_cb(display, example_lvgl_flush_cb);
ESP_LOGI(TAG, "Register event callbacks");
esp_lcd_rgb_panel_event_callbacks_t cbs = {
    .on_color_trans_done = example_notify_lvgl_flush_ready,
ESP_ERROR_CHECK(esp_lcd_rgb_panel_register_event_callbacks(panel_handle, &cbs, display));
ESP_LOGI(TAG, "Install LVGL tick timer");
// Tick interface for LVGL (using esp_timer to generate 2ms periodic event)
const esp_timer_create_args_t lvgl_tick_timer_args = {
    .callback = &example_increase_lvgl_tick,
    .name = "lvgl_tick"
esp_timer_handle_t lvgl_tick_timer = NULL;
ESP_ERROR_CHECK(esp_timer_create(&lvgl_tick_timer_args, &lvgl_tick_timer));
ESP_ERROR_CHECK(esp_timer_start_periodic(lvgl_tick_timer, EXAMPLE_LVGL_TICK_PERIOD_MS * 1000));
ESP_LOGI(TAG, "Display LVGL UI");
example();
while (1)
    // raise the task priority of LVGL and/or reduce the handler period can improve the performance
    /* Try to take the semaphore, call lvgl related function on success */
    if (pdTRUE == xSemaphoreTake(xGuiSemaphore, portMAX_DELAY)) {
        //ESP_LOGI(TAG, "xGuiSemaphore take OK");
        lv_task_handler();
        xSemaphoreGive(xGuiSemaphore);
and what?
as i know we can use the image decoder with LV_COLOR_FORMAT_RGB565A8 !! im using lvgl 9.2.0
Images yes , framebuffer no
